Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Jul 15, 2014 at 7:58 PM
    skygear
    skygear [OP]                    
    Another option would be to have NO negative run in the weather pack connectors. and NO run for the switches. Just having the weather pack connection on the end of the 87 (out to accessory) and the 86 (Switch in/out/ trigger). This would allow YOU to run your own leads with the Weatherpacks
  2. Jul 15, 2014 at 8:00 PM
    skygear
    skygear [OP]                    
  3. Jul 15, 2014 at 8:01 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
  4. Jul 15, 2014 at 8:03 PM
    skygear
    skygear [OP]                    
    Yep. You need the FEMALE connector. Looks like the Male connector is on the end of that. But with the link I sent, it has BOTH so you are good to go.
  5. Jul 15, 2014 at 8:04 PM
    nfs257
    :bowdown:
  6. Jul 15, 2014 at 8:04 PM
    nfs257
    I'm making that harness myself. I have the light it goes to with the female end on it. Lol
  7. Jul 15, 2014 at 8:06 PM
    skygear
    skygear [OP]                    
    Ah, makes sense now. Looks like a little inspiration goes a long way lately! Awesome;)
  8. Jul 15, 2014 at 8:07 PM
    nfs257
    Yes sir! I have everything needed but that damn weatherpak connector. Lol
  9. Jul 15, 2014 at 8:09 PM
    skygear
    skygear [OP]                    
    the shipping KILLS on those things. Part is cheaper than the ~$5 shipping.
  10. Jul 15, 2014 at 8:10 PM
    nfs257
    Wonder if i can find one local?
  11. Jul 15, 2014 at 8:17 PM
    skygear
    skygear [OP]                    
  12. Jul 15, 2014 at 8:29 PM
    nfs257
    Bought and paid!
    Thank you!
  13. Jul 15, 2014 at 8:30 PM
    skygear
    skygear [OP]                    
    Awesome. Read his reviews. Looks like they are fast shipping. Hope for 3 days or less to you!
  14. Jul 16, 2014 at 7:22 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Stock
    I, as I noted in your build, lack electrical know how for the most part. If I got the smaller panel, it would be good for 5 relayed accessories which as I understand each also use one of the fuses, and I would have 5 fuses left for non-relayed accessories correct?
    And if my thinking is correct, the only accessories that would really need relays would be switched (lights for the most part).
    If you could confirm my thoughts or correct me that would be great! I may be interested sometime in the future in one of these!
  15. Jul 16, 2014 at 8:51 AM
    #35
    skygear
    skygear [OP]                    
    Yep you are correct. High amp draw things use relays. Like lights, compressors, pumps etc.
  16. Jul 16, 2014 at 9:32 AM
    #36
    skygear
    skygear [OP]                    
    At a minimum, 5 used so the relays are fused leaving 5 free.
    I like to include 1 constant power for the switches. So that world be 6 used 4 free.
    However, the Constant power is not a must. You can get power anywhere in the cab.
    Some people would prefer to have on with key power from the cab, versus having the switches powered all the time. It is all personal preference.
  17. Jul 16, 2014 at 9:36 AM
    #37
    skygear
    skygear [OP]                    
    Depending on what you do want. I can include a loose power wire in the braided loom. That way all you have to do is to pull the wire out a little wherever you want to tap into power in the cab.
    Since you would be going right past the fuse block. I could include a fuse tap to make things real simple.
    Remove a stock fuse. Drop in new fuse into the fuse tap. Connect wire from fuse tap to the loose power wire in the harness. Plug in the fuse tap.
  18. Jul 16, 2014 at 9:41 AM
    #38
    skygear
    skygear [OP]                    
    Whatever options were chosen, I can provide pictures, walk throughs, and live support online or phone to help
    -no charge-
    Round trip plane ticket, gets free install ;)
  19. Jul 16, 2014 at 9:43 AM
    #39
    NC15TRD
    Nick
    PA
    16 Silverado Z71
    Stock
    I thought I was right. Just nice to know I'm not :goingcrazy:
    I would rather just have keyed power. Prevents someone from bumping a switch and turning on something that could kill the battery.
    This sounds like a winner of an idea! Actually now that I think about it, I have a fuse tap already installed for my interior LEDs. They only come on when I have the parking lights on.
  20. Jul 16, 2014 at 9:44 AM
    #40
    NC15TRD
    Nick
    PA
    16 Silverado Z71
    Stock
    :thumbsup: Probably no need for the install offer. I think I can handle it when the time comes I have stuff that needs the power!
Thread Status:
