Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Dec 5, 2014 at 9:36 PM
    #601
    skygear
    skygear [OP]                    
  2. Dec 5, 2014 at 9:37 PM
    #602
    skygear
    skygear [OP]                    
    Yep. But there are different materials that are put in this form factor. Some you can use on hardwood floors and others on space ships. So they are similar, yet very different.
  3. Dec 5, 2014 at 9:43 PM
    #603
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Wow. Mind blown
  4. Dec 5, 2014 at 9:46 PM
    #604
    skygear
    skygear [OP]                    
    Dane. I'll get you later today. I have to catch a couple hours to be able to stay focused today. Also, now that I know what you want, I'll start the process after I finish these.
  5. Dec 5, 2014 at 9:54 PM
    #605
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Hey don't worry about it take your time. Get back to me when you can :)
  6. Dec 5, 2014 at 10:01 PM
    #606
    skygear
    skygear [OP]                    
  7. Dec 6, 2014 at 5:20 AM
    #607
    skygear
    skygear [OP]                    
    Ran out of 14 gauge red. Will get some in an hour
  8. Dec 6, 2014 at 5:45 AM
    #608
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    How much is one like this?
  9. Dec 6, 2014 at 7:16 AM
    #609
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    those connectors :drool:
  10. Dec 6, 2014 at 8:33 AM
    #610
    skygear
    skygear [OP]                    
    That particular build bills out like so.
    100 small box
    50 3/2 split advanced loom with +hot, +ignition, -ground/negative
    50 (10x5 each) weatherpack
    5 3rd Buss
    80 (10x8 each) breakers
    45 (20x2.25 per foot) marine grade 4 gauge wire
    7.50 4 gauge ring terminals copper 4 of them
    2.50 fuse tap for ignition on
    12.75 shipping flat rate
    352.75
    If you took off all the additional things you didn't want. Went with harness and weatherpack
    100 small box
    50 advanced long harness
    50 weatherpack (5x10)
    5 3rd Buss
    2.50 fuse tap
    12.75 flat rate shipping
    220.25
    Or any combination you prefer
  11. Dec 6, 2014 at 8:48 AM
    #611
    skygear
    skygear [OP]                    
    Lots of the Jeep guys contacting me. I do not discriminate. Rather you have a solid product to protect your investment. Doing an FJ install this comming week. Did 3 TJ's installs over the summer too.
    That is not including all of the ones I have shipped. The Polaris & LR guys love my gear too!
  12. Dec 6, 2014 at 9:53 AM
    #612
    skygear
    skygear [OP]                    
    Fuse taps
  13. Dec 6, 2014 at 5:19 PM
    #613
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Your work looks impeccable! Have you considered using multi-conductor wire for the run to your switches? I've used it in the past for a few of my projects that required multiple input/return paths.
    I like your idea for a common negative buss run, especially since it's embedded in glue/sealant.
  14. Dec 6, 2014 at 5:31 PM
    #614
    skygear
    skygear [OP]                    
    Yes. I planned on getting some. Issue I have is this though. Lots of my harnesses are SPLIT. Multi conductor wire is not the best for splitting and splicing other wires into them. HOWEVER. It is your money, I will build it the way you tell me to.
    For an install this coming weekend, I have some in transit. Braided loom in different colors too.
    I also like the soft texture to this wire. Easily moved through the cab. With a quick pull of the braided loom, it can become stiff. With the multi conductor wire, I found it is generally medium stiffness and wants to stay curled up. Not a bad thing, just an attribute of the wire. The stuff I currently use stays flat and still maintains the similar diameter to the multi conductor wire.
  15. Dec 6, 2014 at 5:45 PM
    #615
    skygear
    skygear [OP]                    
    For the 5 relay box, I generally use
    5 switch/ trigger wires
    1 hot
    1 neg
    1 ignition - this wire is always pulled about 2 feet out of the harness from the box. So you can access the fuse box to tap ignition using an add a fuse.
    So an 8/9 conductor would work. Ask me to split that stuff ? its not an easy task. can be done. just not as simple as making the harness I normally do. Lots of people want the 3/2 split.
    On a 3/2 split. I actually split and solder in an additional +/-/ign in there. I need to have some on hand to explore its capabilities.
  16. Dec 7, 2014 at 9:00 AM
    #616
    skygear
    skygear [OP]                    
    Sunday packages
  17. Dec 7, 2014 at 9:02 AM
    #617
    Bennett707
    Oregon
    skygear I am going to attempt to wire some stuff today... you may or may not be getting a frantic text from me when I cannot figure out the ignition tapping thing lol
  18. Dec 7, 2014 at 9:46 AM
    #618
    skygear
    skygear [OP]                    
    No stress. People get pics of their boxes up for the masses
  19. Dec 7, 2014 at 9:47 AM
    #619
    skygear
    skygear [OP]                    
    In the first post, there is a pic of a first and second Gen slot to use the Fuse tap in
  20. Dec 7, 2014 at 3:24 PM
    #620
    skygear
    skygear [OP]                    
    Bennett, you get it done?
Thread Status:
