Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Apr 17, 2015 at 12:15 AM
    #1701
    skygear
    skygear [OP]                    
    let me know if they are useful. I'm quicker and more precise when I am not taking my time like that. Like a machine when I get going. No mistakes.
  2. Apr 17, 2015 at 3:19 AM
    #1702
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yes OTRATTW. I don't have them yet and they are bottom light.
  3. Apr 17, 2015 at 3:22 AM
    #1703
    ThomasMore66
    Those are some serious crimpers. I may have to go by the store for some more tools.
  4. Apr 17, 2015 at 9:27 AM
    #1704
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Well like Sky said since you are getting switchbacks pre-wired from him you will be good to go
  5. Apr 17, 2015 at 10:26 AM
    #1705
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Mike,
    Thanks for all your help the other day over the phone when I was installing my box. I got everything together and it works great. Except one problem I didn't think about. My OTRATTW switches are lower independent/upper dependent. Three of the 5 work great but the other two only the top light works. Those are my ARB compressor and locker. The wiring harness they are on (stock ARB one) is only made for an upper dependent switch. I need to figure out a way to tie them into your harness to power the lower independent LED. Other than that, everything works just like it should! I know I promised pictures but I had to rush to get my dash back together and leave town for a family function. I'll get some pictures this weekend though since I'll have my dash apart again anyway.
    Thanks!
  6. Apr 17, 2015 at 9:34 PM
    #1706
    ThomasMore66
    I'm working on my problem...830f743555f70cf827912a52fc82e044_d0d5d4610148d086d9ed2cf1b690cbe943cb7698.jpg
  7. Apr 18, 2015 at 9:56 AM
    #1707
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Ordered a mounting plate.......now to order a box........:goingcrazy:
  8. Apr 18, 2015 at 10:05 PM
    #1708
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Hey sky, I sent you an email and a pm but in case they get lost I'm interested in canceling my order. Invoice was #2769. As stated in the messages I'm not angry about the production delay, I have simply decided to go a different route on my truck build. I'm gonna postpone electrical upgrades til a bit later. So if my money could be refunded I would greatly appreciate it.
  9. Apr 20, 2015 at 4:35 PM
    #1709
    Madjik_Man
    Colorado Front Range
    Got my order. High quality craftsmanship for sure.
    Skygear, I will definitely pick your brain a bit via email to really dial in my installation but it does seem pretty straight forward.
    Really digging the Cobra adapter/disconnect in the OTRATTW blank.
  10. Apr 20, 2015 at 4:58 PM
    #1710
    skygear
    skygear [OP]                    
    No more SPOD for this Jeep ---- @ dirtroadtrip.com
    Before
    4d0b8e9263fd743caf9c7f74677db345_0095cf16782a294bb8812fd210e121b2d9b228c5.jpgbf5324ea61d5482fde38c574e65e2938_94982eac40b0bd055f82b9187d19f4d8d489c3ad.jpgdbddb1d860c5b7564571223e9150e9af_ff4b73fe9a4d9a3e055e2498a901fed923623105.jpge9b2e9d1e0a5e6301f7ad7d4b7344de5_3a9ea943c611046e9922df7357040c68d1e7eeeb.jpg
    After
    8c0315fec4356863a56d5208a879718a_4d97b08d4a9c3c915b1691c9ed86ef8eb6cc0364.jpg270132beae0f73547db9606b823b56ca_9e6af1bde69815a277562758977bec236cb808c7.jpg7ebcf6db729079e459cf9cb2c8e57a7b_9422481cbf2b3625a27374c9eb85ff7a3268bebf.jpg46c6ed431f8fc5b68f135788dde024da_9a65ab03140f67a4355736e120051ea7aa652da4.jpg
  11. Apr 20, 2015 at 5:01 PM
    #1711
    skygear
    skygear [OP]                    
    c3d10125d3f70ba85b775d6f9037213d_97edef12326e96ef14d8ca702a19993c1ec36fab.jpg23c375fd73fa628e269e3346b218b3e3_1fdf0f910ef308e606d3b992bd3693d53cdea423.jpgc6aa6ce4cf74236e07625b7f4bc5e626_9961d9720ad877ce645925964a5cb297c3bbeebf.jpg
    Midland CB mod
  12. Apr 20, 2015 at 5:06 PM
    #1712
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    New orders? :poking: :D:D:D
  13. Apr 20, 2015 at 5:19 PM
    #1713
    skygear
    skygear [OP]                    
    I want a few more people to post their orders up.
  14. Apr 20, 2015 at 10:37 PM
    #1714
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I need one of those cb covers
  15. Apr 21, 2015 at 12:27 AM
    #1715
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    What do you mean by this exactly??
  16. Apr 21, 2015 at 12:55 AM
    #1716
    pheerles
    pheerles Well-Known Member
    Rosemead, CA
    '15 Access Cab 4x4
    Whats the status on order 2764.
  17. Apr 21, 2015 at 7:37 AM
    #1717
    reidbailey
    reidbailey Well-Known Member
    Reid
    Redondo Beach
    2011 4Runner
    Think he's asking to post pics when people receive their order.
  18. Apr 21, 2015 at 8:02 AM
    #1718
    Madjik_Man
    He's asking those of us, who have been waiting a while, to post up pics of our respective orders to prove to many that he is indeed shipping them now.
    And Pherles - Skygear did say he shipped out 15 orders on Saturday. I have to assume yours has to be one of them. I believe you ordered right around the same time I did.
  19. Apr 21, 2015 at 10:48 AM
    #1719
    roguetrader
    roguetrader Well-Known Member
    OK so What's your answer for 2747?
  20. Apr 21, 2015 at 11:51 AM
    #1720
    Madjik_Man
    Is this a trick question? :confused:
    I'm a customer, not the vendor.
Thread Status:
