Waterproof Fuse and Relay Boxes - RFRM (10 relay) & RTMR (5 Relay) no Blue Sea/ SPOD
Discussion in 'Buy / Sell / Trade' started by skygear, Jul 15, 2014.
Thread Status:
Not open for further replies.
  1. Apr 28, 2015 at 1:53 PM
    #1741
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    Me! I have been trying to order switch backs for quite a few months.... No order has been processed though.
  2. Apr 28, 2015 at 7:32 PM
    #1742
    Alament92
    Alament92 Well-Known Member
    Austin
    Arizona
    2012 Tacoma TRD Sport
    HID's, Rancho quicklift, 295/75/16 Nitto Terra Grapplers, Method Race Wheels, K&N CAI, LED interior dome, map, license plate lights, 30 inch Avec LED light bar, Anti-dark hood lighting kit
    Would I need the relays, or just the fuse box? Probably the 5 relay, since my light bar and HID'S have relays huh... Then bed lighting and hood lighting kits just have a fuse which can go right into this.. Hmm
  3. Apr 28, 2015 at 7:47 PM
    #1743
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Definitely relays....if you want just fuses get a bluesea fuse box, but this will make all your wiring simplified.....you will have 5 relays that are fused and you will have an additional 5 fused sources for things only requiring a fuse
  4. Apr 30, 2015 at 8:31 PM
    #1744
    ttran076
    ttran076 Well-Known Member
    Orange County, CA
    2014 Tacoma Sport 4x4
    Kings, TC UCA, Dakars, Prinsu rack, ARB Snorkel, Method NV, Wildpeak AT3
    @skygear following up on my order status. Sent you some emails to your gmail account but no response.
  5. Apr 30, 2015 at 8:34 PM
    #1745
    skygear
    skygear [OP]                    
    send me one now and I'll look. Spam filter is ridiculous lately. I need to stop using the outlook client and just use the gmail from now on.
  6. May 1, 2015 at 9:18 AM
    #1746
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Sent you an email for a follow up Mike. Thanks for your hard work!
  7. May 1, 2015 at 7:01 PM
    #1747
    ttran076
    Orange County, CA
  8. May 2, 2015 at 5:02 PM
    #1748
    srye
    srye Member
    Oklahoma
    1964.... haha
    skygear, I sent another e-mail
  9. May 2, 2015 at 6:15 PM
    #1749
    skygear
    skygear [OP]                    
    Gmail client it is then. Leaving tonight for the west
  10. May 2, 2015 at 6:21 PM
    #1750
    srye
    srye Member
    Oklahoma
    1964.... haha
    Skygear, Did you get mine out??
  11. May 2, 2015 at 8:08 PM
    #1751
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    edit- answered my own question :)
  12. May 2, 2015 at 9:39 PM
    #1752
    NotRed
    NotRed Well-Known Member
    same question......
  13. May 2, 2015 at 10:00 PM
    #1753
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    X's 2??
  14. May 3, 2015 at 3:41 PM
    #1754
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Skygear, I saw you previously advise someone that the "5th pin" of the relays you ship can be used as a second trigger. As I got around to planning my box a bit more this weekend, I looked up the schematics of that relay, and I'm not seeing how that can be the case. If you hook the supply +12V to pin 30 and the accessory to pin 87, then pin 87a (the "5th pin) would be at +12V when the relay is not powered and wouldn't act as a secondary trigger at all. If you switch it around, and put the supply on pin 87 and the accessory on pin 30, you're simply shorting pin 87a to the accessory. If you were doing this to have the high beams trigger a light bar that is also on a switch, for example, you'd either be driving the lightbar on the high beam circuit (which could blow your high beam fuse) or through the switch (which may be overpowered for smaller wire you run through the cab, and bypasses the fuse, which is kind of the point of the fusebox).
    It does still appear that you'd just need to add a diode to both triggers and then wire them both to pin 87, or use two relays with everything in parallel except the triggers.
  15. May 7, 2015 at 4:10 PM
    #1755
    bry838
    oregon
    Whelp in a few short days I will have been waiting 5 months for a box! After being told two weeks at the time of order and several times of being told "it shipped" or "bout to ship" or "in the next batch waiting shipment" and finally something along the lines of I'll fulfill the outstanding orders before my trip. Guess what!? Still no box! This is getting fucking old!!!!! Been waiting since January WTF?
  16. May 7, 2015 at 4:59 PM
    #1756
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    With a 5-pin relay that has pin 87a, you have to look at the relay as a SPDT switch and not as a primary and secondary trigger.
    For example, with your switch in the off position so that no power is energizing the relay coil, pin 87a is hot. This is the normally closed default position with power supplied to 87a from pin 30. When you flip your switch and energize the coil, the relay is triggered, which powers pin 87 and takes power away from pin 87a.
    If you look through the list of diagrams at the following link, you'll see several situations where you might find a 5-pin relay useful:
    http://www.the12volt.com/relays/relaydiagrams.asp
  17. May 7, 2015 at 5:46 PM
    #1757
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I don't understand why anybody waits 2 months, let alone 5. Good luck with that.
  18. May 7, 2015 at 6:58 PM
    #1758
    azchris
    Prescott, AZ
    I'm aware of how relays work, I described the exact same thing in my post. Skygear was advising the "fifth pin" which I assume refers to 87a can be used as a secondary trigger. Pin 87a is simply for use as a normally-closed circuit, as you described.
  19. May 7, 2015 at 7:16 PM
    #1759
    tacozord
    2015 DCLB 4wd SR5
    Ok. So we're on the same page then. My bad for not reading your post thoroughly. D'OH! :frusty:
  20. May 7, 2015 at 11:58 PM
    #1760
    bry838
    oregon
    Redicioulous right?? Not one time have i recieved an update or an appology, or even just a short explanation as to why the massive time delay. A little communication can go a long way...Still setting on all my accessories waiting to be used/installed...no power to them unless I wanna start running wires and inline's from the battery.
Thread Status:
