Waterproof RCA Video Connection Ideas
Discussion in 'Audio & Video' started by orion808, Jan 12, 2019.
  1. Jan 12, 2019 at 9:04 PM
    orion808
    orion808 [OP] Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    I'd like to have a connection for a camera that requires a power connection and RCA video connection that would be under my tonneau cover, but I'd like them to be waterproof. I'm drawing a blank as to how to set this up and google searches aren't sending me down the right path.
    Should I put the connections in a box or are there waterproof connections already that I could plug and un-plug the camera as needed?
    Any help is appreciated and once I'm done with this project, I'll have a "how-to" in another thread.
    Also, I don't mind doing some soldering, but haven't messed with RCA. I'm researching on the side if it's worth it to turn the RCA into a standard connector of some sort.
  2. Jan 13, 2019 at 8:53 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Just use the included RCA connections on most cameras and put some ½” adhesive lined heat shrink over it. Water sealed for good.
    mctechhweng likes this.
  3. Jan 13, 2019 at 4:42 PM
    orion808
    Florida
    I know i can shrink wrap it and hide it, but i was hoping for a temporary connection so that i can unhook when not needed. I was hoping for something like a permanent plug.
    I might have to make a box and cut into the bed to have it hidden and, therefore, waterproof. I'd just plug the rca video and power of the camera in as needed.
  4. Jan 13, 2019 at 5:10 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Ahh didn't know we needed it removable. I've had good luck with these
    https://www.amazon.com/MUYI-Waterpr...coding=UTF8&psc=1&refRID=RNH3AJNZ773E4R1222FA
    the wiring is 16awg which is a bit thicker than I'd like for a backup cam, but it will work if you're halfway decent with a soldering iron.
    one connector for video + and -, and one connector for cam power and ground
    edit* found a 4-pin with 18awg so that would be my suggestion
    https://www.amazon.com/MUYI-Waterpr..._5?s=automotive&ie=UTF8&qid=1547428265&sr=1-5
