Waterproof wire entry into bed floor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitetaco16, Dec 15, 2018.
  1. Dec 15, 2018 at 9:13 AM
    whitetaco16
    whitetaco16 [OP] Well-Known Member
    James
    Central NC
    2016 TRD OR Access Cab Long Bed
    Dobinson's 2.5, RCI Sliders, Mobtown Recovery Bar and Front Skid, 4.88's and Extremeaire Magnum
    I need to get two 8 gauge wires into the bed floor on my 3rd gen. It needs to be waterproof as well. The wire needs to go through and continue without being cut at the entry point so typical connectors are not the solution. I'm sure something exists but need help finding it. Any ideas?
  2. Dec 15, 2018 at 9:20 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I’d start looking for something like that in a boating or marine parts catalog......
  3. Dec 15, 2018 at 9:24 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    What's the application? Easiest entry into the bed are the drain holes in the side storage boxes, then route as needed behind the hatch or liner. I wired a 3rd taillight through that way using meager 16 gauge, and since I didn't drill it's easily reversed if I need to.
    8G? Depending on location of your appliance you might need to drill up from underneath. Run your wires then use a firewall gasket, or if you're cheap, silicon seal the penetration points .
  4. Dec 15, 2018 at 11:34 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    :thumbsup::taco:
  5. Dec 15, 2018 at 11:40 AM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Drill it. The beds are composite and won't rust. I have drilled about 6 holes in my bed so far. Otherwise the cubby as stated earlier is a good choice
  6. Dec 15, 2018 at 11:56 AM
    whitetaco16
    James
    Central NC
    Thanks for the input. Drilling the floor is not the problem, how to attach a strain relief and waterproof it is where I need help.
  7. Dec 15, 2018 at 12:03 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
  8. Dec 15, 2018 at 12:40 PM
    whitetaco16
    James
    Central NC
    Thank you gotblika! That appears to be exactly what I need.
    gotblika likes this.
