Waterproofing Roof After Roof Rack Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Road_Warrior, Feb 3, 2022.
  1. Feb 8, 2022 at 11:07 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    you have the same problem with what you did plus you added an area where water can collect.
  2. Feb 8, 2022 at 11:07 AM
    Road_Warrior
    Road_Warrior [OP] There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Answered above :thumbsup:
  3. Feb 8, 2022 at 11:08 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I'd be worried about that slight crack/tear on the left (as in pic). That's just film that's painted. Water can still seep in there.
  4. Feb 8, 2022 at 11:08 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    If it doesn’t work I’ll just remove the tape and reapply it over the entire area.
    like I said, it shouldn’t be an issue since the holes are fully sealed underneath the tape.
  5. Feb 8, 2022 at 11:10 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I noticed that as well, close up it’s actually just a build up of paint where they didn’t do a smooth application.
    Sig45[QUOTED] likes this.
  6. Feb 8, 2022 at 11:12 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I think your sealing approach will work just fine OP. And why wait for rain, grab a hose and wet her down!
  7. Feb 8, 2022 at 11:19 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Well I’m glad someone thinks so :rofl:
  8. Feb 8, 2022 at 11:24 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Road_Warrior[OP] likes this.
  9. Feb 8, 2022 at 12:24 PM
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    I had asked a question a while ago and I don't think people knew the answer then. But what's the actual layout/structure of that area that is actually let's water in? I would have assumed the bolt holes don't go directly into the cab but would have the ends of the threads capped off?
  10. Feb 8, 2022 at 1:00 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    So I’m not 100% sure but I can tell you that when I have had water come into the cab, it has come in through the A pillar at the seam between the side curtain airbag and where the roof fabric starts; and also through the B pillar where the seatbelt is mounted.
  11. Feb 8, 2022 at 1:15 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    This was the factory seal on my 2nd Gen;
    When I took the rack off and traded it in I plugged the holes with silicone, then electrical taped over top like the factory, then new trim pieces. Chatted with the new owner two years later and it was still fine.
  12. Feb 8, 2022 at 1:28 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That’s great to hear. Hopefully it will work just as well for my 3rd Gen.
  13. Feb 8, 2022 at 4:35 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Totaled..... The gorilla tape looks like it's not even adhered on all four sides.
  14. Feb 8, 2022 at 5:11 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    You would be correct sir. There was some glue from the factory tape that wouldn’t come off so it wasn’t a completely smooth surface.
    I have since sealed those edges of the tape with silicon.
  15. Feb 9, 2022 at 1:17 AM
    #35
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Your fine, looks like a solid jub. Maybe clean up a little and add another layer of tape.
  16. Feb 9, 2022 at 3:45 AM
    #36
    cropduster78
    cropduster78 Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    OP - why did you remove the Prinsu?
  17. Feb 9, 2022 at 4:40 AM
    #37
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Good question. I do a lot of highway driving (hence the user name) and the wind noise was just too much for me. It’s an awesome product, it just want the best fit for my use.
    I found that with BillieBars I could carry the things I needed the roof rack for and still maintain full access to my bed. It also doesn’t affect my MPGs at all. I also have the Bakflip MX4 bed cover.
    This is my current set up:
    cropduster78[QUOTED] likes this.
  18. Feb 9, 2022 at 4:40 AM
    #38
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Sounds like a smart idea! I appreciate the input.
  19. Feb 9, 2022 at 4:58 AM
    #39
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
  20. Feb 9, 2022 at 5:07 AM
    #40
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
