waterpump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bdogberger, Mar 6, 2016.
  1. Mar 6, 2016 at 8:13 PM
    bdogberger
    bdogberger [OP] New Member
    brandon
    2011, Tacoma 4 door long bed 4x4
    None yet
    How much noise should my water pump make? Sounds winny like a bad stereo ground. Is this a sign of the pump going bad. Should a good pump make any noise at all?
  2. Mar 7, 2016 at 12:19 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I couldn't distinguish the WP noise from other noises. Could be a bearing from alternator or idler pulley, fan clutch, belt, etc... A stethoscope can be used to pinpoint the noise maker.
    But, no, normally, WP will not whine. If you do think it's the WP, remove serpentine belt and check pulley for play or roughness when you rotate pulley.
  3. Mar 7, 2016 at 12:31 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    A water pump makes a grinding sound in my experience from the bearing going bad and the fins wallowing out the inside of the pump. Like Chuy said, pull the belt and spin the water pump to see if you have any excessive play/noise. A good water pump shouldn't make any sounds.
