Watomi fogs on eBay
Discussion in 'Lighting' started by TenBeers, Jun 5, 2009.
  1. Jun 5, 2009 at 6:11 PM
    TenBeers
    TenBeers [OP] Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The kit says it comes with the lights, a relay, wiring and a switch. There are some posts here that indicate the lights are a match for the OEM ones and that the switch doesn't fit correctly without some fabrication.
    My question is about the relay that comes with the kit and the connectors. Does it plug into the relay box? And do the connectors on the lights plug directly into the stock wiring harness?
    I'm wanting an install that is clean and stock, I don't want to hack up the wiring on a brand new truck or run additional wires through the firewall. My truck has the wiring, but no relay. I'm just trying to figure out what I need to buy without spending extra money (I'm already adding window tint, Westin step bars, and a tow hitch). I just miss the extra lighting my Tundra fogs gave me, helps spot those deer out here in the country.
    TIA
  2. Jun 5, 2009 at 6:41 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    do you have a link to the lights your talking about?
    more than likely they will not plug into your factory harness.
    Its not hard to run two wires into the cab...
  3. Jun 5, 2009 at 7:01 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Below is a link to the Watomi kit. As I mentioned, there are other posts indicating that the lights are a direct OEM fit, I am just wondering if I need to buy an OEM relay and connectors to avoid any cutting or splicing into the original harness. You can't tell from the info or pictures.
    I have plenty of wire and other materials from my restoration projects, and running the wires is not a problem (I can hack as good as anyone, LOL). But there's already wires run, and I don't want to hack into a harness on a truck that is a week old. :) And I don't want to pay Toyota prices if I don't have to!
    http://cgi.ebay.com/ebaymotors/05-0...14&_trkparms=65:12|66:2|39:1|72:1205|240:1318
  4. Jun 5, 2009 at 11:42 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  5. Jun 6, 2009 at 6:12 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I've got the yellow version of those lights. I used the harness that came with it, but I modified it to work with the Toyota rocker switch...the $10 one, not the $50+ OE one. I didn't have to hack any of the factory wiring at all. I just cut off the parts of the harness I didn't need. I added one of those "add-a-fuse" fuse holders and installed it in an empty slot in the fuse box that's hot when the parking lamps are....so my fogs work with the parking lamps, low-beams and high-beams. They turn on and off with the head lamp switch or I can defeat them all together with the rocker switch. LMK if I can help ya out...with advice and/or pix.
    Relay leads:
    White (+) - Battery
    Black (-) - ground
    Red (+) - to lamps
    Yellow (+) - relay signal
  6. Jun 6, 2009 at 12:38 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    So from the responses, I am assuming that:
    - The lights are a direct fit (snap right in just like stock)
    - They have the proper connectors to plug directly into the stock wiring harness
    - The relay provided with the kit is NOT the Toyota relay that will plug into the fuse/relay box
    - The switch, as others have said, does not fit exactly.
    So for a completely stock setup (which is what I am looking for), I'd need the Watomi kit, an OEM relay, and an OEM switch, correct?
    The OEM switch is $40, relay is $20. Still not bad for a complete stock setup -- about the price of 1 stock light!
  7. Jun 6, 2009 at 12:46 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    - yes the lights will snap right in
    -no, they will not plug into the factory wires, you will need to cut off the little factory plug and splice in the new lights.
    -idk about the realy
    -no the switch will not be a fit
    heres a link to a much cheaper switch that will fit
    http://www.oznium.com/gsw-45
  8. Jun 6, 2009 at 8:02 PM
    Plain Jane Taco
    USA
    As I mentioned, I did not splice into any factory wiring. So you don't have to if you don't want to. Even with the $10 Toyota Rocker fog lamp switch, you'd never know that my setup is not OE....unless you were some sort of Tacoma junkie....but the average person? No way.
    I can post pix of my setup if you'd like.
  9. Jun 7, 2009 at 7:00 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Thanks guys, and thanks for the link to the switch.
    The stock wiring harness plug at the light is a standard headlight plug, so I can get a couple at the local auto parts store and splice them into the harness that comes with the lights if necessary.
    I think I'll still pay the extra $30 for the OEM switch so it will plug directly in to the connector at the dash. I'm not afraid of splicing or soldering or running new wires, I just know that I don't have to, so I don't want to do that in this case.
    If I put a bull bar on with a couple of lights, I'll run new wiring then (and use the cheaper rocker switch).
  10. Jun 7, 2009 at 4:13 PM
    Plain Jane Taco
    USA
    If you're talking about the plugs for the fog lamps, then the harness that comes with the lights already has them...no need to buy any.
  11. Jun 14, 2009 at 3:25 PM
    Plain Jane Taco
    USA
    Here's a few pix of my foglamp setup if this helps.
    Here's the $10 Toyota rocker switch.
    In the '09 base there is an unused slot in the fuse panel that is "hot" when the parking lamps are on. I used this as my signal for the relay. I installed an Add-A-Fuse connection with a 5 amp fuse in the circuit and a 2.5 amp fuse for the signal wire. Doing it this way allows the fogs to operate with the parking lamps, low beams and high beams. They will shut off with the headlamp switch or can be defeated completely using the rocker switch.
  12. Jun 15, 2009 at 8:48 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Nice job there, very clean, and good pics.
    There's another seller on eBay that has just the lights for cheaper, think I am going to go that route and get the stock relay and switch.
  13. Jun 15, 2009 at 1:43 PM
    Plain Jane Taco
    USA
    Thanks.
    Yeah....since you're pre-wired, I'd go that route as well. Being a base model, though, I had to start from scratch.
  14. Aug 4, 2009 at 10:08 AM
    rd263
    rd263 Banana Republic
    Southeast of Disorder
    2006 SW SR5 4X4 AC
    Billy 5100's front,5% tint rear,20% sides,35% full front,Kenwood head unit,DRL mod,AFE CAI,Thule rack system,TSB rear leaf upgrade,Hella headlamps,Vent visors,Led brake lamps,Led backup lamps,clutch squeak TSB,TO bearing fixed,Debaged,100 watt fog lights ,Popnlock,shorty antenna,door sill protectors.
    Plain jane,
    Great pics,I have been wanting to see that set up since i got my truck
    Thanks !!!
  15. Aug 5, 2009 at 12:55 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    i already have fogs on my truck, can i just change out the housings to have yellow ones or will have to rewire everything to get things working?
  16. Aug 5, 2009 at 2:50 PM
    Plain Jane Taco
    USA
    Thanks. I've had several questions and compliments from people I work with about where I got yellow fogs. :D
    Yep.
  17. Aug 18, 2009 at 10:02 AM
    happyb
    Brandon
    to my taste
    making a list
    i just installed these ebay fogs and the fitment is not exact to oem. there are gaps around the edges so the lights do not fit flush into the opening. i think i will have to shave some of the bumper so it fits more flush. another thing is that i had the hardest time aiming one of the lights, it took me forever to try and aim it correctly. maybe i didn't get a perfect one.
  18. Aug 21, 2009 at 5:55 AM
    Plain Jane Taco
    USA
    Strange....mine were perfect. In fact, the other day I tool a close look at a Taco at work with OE fogs and they were exactly the same....well, besides my yellow lenses. I only had to slightly adjust the left one to get them aimed.
  19. Aug 21, 2009 at 6:16 AM
    Niknaq
    Niknaq Phightin Phils 2008 Champs
    Nick
    FLA
    2009 4wd 2.7L Regular Cab
    Dumped exhaust, 35 % factory tint, kobalt slim line toolbox, afe pro dry, toyota all weather mats, fog lights soon.
    pane jane which fogs did you end up going with and what was the total build price? I am sitting in your shoes right now when you were building this up, what did you buy and was it hard to install
  20. Aug 21, 2009 at 10:09 AM
    happyb
    Brandon
    to my taste
    making a list
    there are little gaps around the edge that is kinda noticeable. the fogs line up with the holes but it doesn't sit flush in the holes. i had a hard time aiming the passenger side fog because it would aim super high when i adjusted the screw.
