wax ring
Discussion in 'Garage / Workshop' started by coffeesnob, Apr 25, 2012.
  1. Apr 25, 2012 at 12:15 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    What do you think is easier putting the wax ring on the toilet first or the flange?
  2. Apr 25, 2012 at 12:16 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I put it on the flange and set the toilet on top of it.
  3. Apr 25, 2012 at 12:24 PM
    FLtaco
    FLtaco Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    Correct. On flange first then set toilet on it. Unless you have two guys to hold the toilet sideways for you it's way easier.
  4. Apr 25, 2012 at 12:35 PM
    triumphx
    triumphx Well-Known Member
    Austin, TX
    X-runner/cummins
    Set it on the flange, set toilet on top of the wax ring. Then while facing toilet, sit on it slowly til it seats. then tighten the closet bolts equally
  5. Apr 26, 2012 at 3:35 AM
    coffeesnob
    VA
    Is it hard to get the toilet to set squarely on the wax ring?
  6. Apr 26, 2012 at 5:13 AM
    Pugga
    Massachusetts
    Not that I noticed. Like he said, just tighten each bolt evenly.
  7. Apr 26, 2012 at 6:24 AM
    triumphx
    Austin, TX
    X-runner/cummins
    No line up your closet bolts where they are in the middle of the wax ring.For example -0-, the 0 is wax ring and - are bolts. Then just set the toilet down where the bolts poke through toilet. Then sit on the toilet slowly to seat it properly. Its very simple, did you understand my make shift example?
  8. Apr 26, 2012 at 6:28 AM
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    just be careful you don't damage the wax ring putting the toilet over it. I've done than once to many. Those things are hard to clean up if you damage one.
  9. Apr 26, 2012 at 6:29 AM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Another good trick is to put cut-off drinking straws on the bolts. This helps line it up before you seat it.
  10. Apr 26, 2012 at 6:30 AM
    medusa1066
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Rubbing alcohol cleans up the wax pretty good
  11. Apr 26, 2012 at 6:32 AM
    triumphx
    Austin, TX
    X-runner/cummins
    All you have to do is make sure you fully lift the toilet so it doesnt damage it
  12. Apr 26, 2012 at 12:13 PM
    coffeesnob
    VA
    ok guys thanks!
  13. Apr 30, 2012 at 11:04 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    good tip on the straws!
