Ways to add more lift to wheelers progressive AAL in rear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TravelinLight, Dec 22, 2015.
  1. Dec 22, 2015 at 7:42 AM
    TravelinLight
    TravelinLight [OP] Well-Known Member
    Hayes
    Pensacola, FL
    Bilsteins on front and rear, OME 885 coils, Wheeler's AAL with overload left in, LR UCA's, Stock TRD 17" wheels, 255/75-17 BFG KM tires, VIPMOTOZ headlights, Lifetime LED headlight bulbs, 6000K LED Fog bulbs, Jumper's Interior and license plate LED's, Husky Classic floor mats, OEM bed mat, Leer100R truck shell with carpeted platform, de-badged, white derped grill emblem.
    I've got billstein5100 on front and rear with OME885 coils on the front and Wheelers progressive AAL in the rear with the factory spring left in place. The front Billies are set to 0.
    What are my options for adding another 2 inches of lift in the front and rear?
  2. Dec 22, 2015 at 7:58 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I second that. I wouldn't add anything to that AAL. I had a Dakar leaf pack on the rear of my last Tacoma and 5100's. I was told when raising the rear above 2" (Dakar is 2.75") to then get the extended travel 5100's for the back and extended brake lines....
  3. Dec 22, 2015 at 8:10 AM
    evan
    evan Well-Known Member
    SK, Canada
    That setup should be 2.5" front and 1.5" rear, right? So you want 4.5" front and 3.5" rear lift? There's nothing on the market for that without replacing the front crossmember and knuckles AFAIK.
    Arailt likes this.
  4. Dec 22, 2015 at 9:04 AM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    I'm assuming your stock leafs have sagged? A aftermarket leaf pack is your best bet.
  5. Feb 2, 2016 at 10:20 PM
    TravelinLight
    Hayes
    Pensacola, FL
    is adding more leafs to my AAL an option? Or to keep it simple, could I add a 1 or 1.5 inch block to the back and spacers on my front coils? Dont really care about the ill-effects for offroading...dont do a whole lot. I'm doing this for aesthetics.
  6. Feb 3, 2016 at 7:41 AM
    Pigpen
    Dan
    Northwest Montana
    You can do anything you like, or you could follow the good advice posted above.
