Wd-40....
Discussion in 'Off-Topic Discussion' started by monoman, Jun 9, 2009.
  1. Jun 9, 2009 at 10:38 AM
    monoman
    monoman [OP] Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
  2. Jun 9, 2009 at 10:43 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    It looks like the tire comes back off the rim at the end. Was this just a neat trick he was showing off or was it supposed to actually make the truck drivable again?
    Either way... pretty cool trick.
  3. Jun 9, 2009 at 10:44 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    i have never seen that work with WD-40 however either works real well as long as you don't use too much
  4. Jun 9, 2009 at 11:06 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    they "deflammabalized" WD-40 quite a bit. was wickedly falmmable when i was a kid.
  5. Jun 9, 2009 at 12:24 PM
    VancityCK
    VancityCK Well-Known Member
    Vancouver
    09 Magnetic AC TRD Offroad
    I thought they used lighter fluid or ether (starting fluid for diesels?). Its supposed to reseat the bead nice and quickly so you can fill it up with air again.
  6. Jun 9, 2009 at 12:26 PM
    Rangerpeterson
    Rangerpeterson Well-Known Member
    Jacksonville, FL
    06 Tacoma
    Hmmm... wow thats pretty cool
  7. Jun 9, 2009 at 12:31 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Yeah it didn't work...but I have seen the either trick by someone for an atv tire.
  8. Jun 9, 2009 at 2:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My luck...I'd have a freak accident occur while trying to do that.
    I've had better luck with ratchet straps & onboard air. ;)
    You could probably get the same affect from using White Rain hairspray (laugh). I remember using that stuff in a friends potatoe canon.
  9. Jun 9, 2009 at 3:14 PM
    22b22
    22b22 Well-Known Member
    Northern California - East Bay
    03 DoubleCab PreRunner TRD SR5
    OME 881/N91S - front Wheeler 5-pack/N85 - rear
    I've seen it a few times. Usually with a flammable brake cleaner. ATV tires are easy.
    Check out all the videos on youtube:
    http://www.youtube.com/results?search_query=seat+bead+flame&search=Search
    Here's the reason for the debeading afterwards:
  10. Jun 9, 2009 at 5:26 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
  11. Jun 9, 2009 at 5:39 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    if it cools and backs it off couldnt you just have your air supply hooked up and running air into it at the same time that way when the bead seeds air will be going into it to prevent it from unseeding? curious...
