WD hitch needed?
Discussion in 'Towing' started by MyTaco, May 10, 2011.
  1. May 10, 2011 at 7:16 AM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
  2. May 10, 2011 at 7:50 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    You'll be fine without the WD hitch until you get a good crosswind. Then it will be worth every cent.
  3. May 10, 2011 at 9:49 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    Agreed. Does your trailer have electric brakes too?
    I'd be wary of that weight without trailer brakes, that's more than the curb weight of the truck itself.
    Expect crosswinds with an enclosed trailer as well.
    Look at it this way, buy the WD Hitch and you can use it on other trailers later. I have one and moving it from a Travel Trailer to another trailer is pretty simple if the tongue heights are close to the same. It's a 5 - 10 minute process once you understand how it all work together.
  4. May 10, 2011 at 10:11 AM
    MyTaco
    Az
    Yes it has electric brakes on both axles. I'd rather error on the side of caution for sure.
  5. May 10, 2011 at 11:37 AM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Then 4200 lbs with that setup should pull pretty good.
    It looks like you've covered your bases, it's all up to you now ;)
  6. May 10, 2011 at 12:16 PM
    MyTaco
    Az
    Sounds good, thanks and wish me luck!
  7. May 10, 2011 at 4:58 PM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    May the force be with you :)
  8. May 11, 2011 at 8:33 AM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    I bought one of those, but they don't include sway bars into them. You have to find a friction swaybar to work with those.
    My preference if I were to do it all over again would get the Reese Dual Cam setup or an integrated trunnion style into the hitch itself like the Equal-i-zer.
    However, if cost is a factor, the $200 dollar Reese Pro series 600 / 6000 round bars work well with an add on friction sway bar.
