We have mud flaps for your Toyota Tacoma
Discussion in 'Agri-Cover' started by ACCESS, Mar 10, 2016.
  1. Mar 10, 2016 at 2:16 PM
    ACCESS
    ACCESS [OP] Active Member Vendor
    We have mud flaps that fit the Toyota Tacoma to a “T.”
    Our ROCKSTAR™ Hitch Mounted Mud Flaps are available in a setup that works great on mid-size pickups like the Tacoma.
    These Toyota Tacoma mud flaps are made for active use on the highway or on gravel roads. The mud flaps are made with extra-thick ½” rubber to reduce sailing. They have a smooth surface to resist ice and mud buildup and can handle temperatures as high as 250 degrees F.
    ROCKSTAR™ Hitch Mounted Mud Flaps have an aluminum frame with stainless-steel hardware for corrosion resistance. The frame is offered in two finishes: smooth mill and diamond plate.
    The entire mud flap package is easy to assemble, remove and re-install as needed. The frame mounts to the hitch with no drilling required using an adjustable clamping system. Adjustable vinyl-capped stops take the guesswork out of aligning the hitch pin whenever you need to tow a trailer.
    Our site, Getmudflaps.com has these Toyota Tacoma mud flaps on sale for 15% off right now, and if you type TACOTIME in the promo code box at checkout, you’ll get a free bonus item with your order.
