We just bought a new camper and my truck will be pulling it, questions and tips
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rimfire7, Apr 22, 2022.
  1. Apr 23, 2022 at 5:43 PM
    rimfire7
    rimfire7 [OP] I'm here for the tacos
    beth
    2021 army green taco
    Toytec lift, old man emu springs, Victory 4x4 front bumper and skids, light bar
    can you share any posts you found helpful?
  2. Apr 23, 2022 at 5:45 PM
    rimfire7
    beth
    Axel-weight? Do you mean weight on top of the camper's axel?
  3. Apr 23, 2022 at 5:49 PM
    rimfire7
    beth
    Thanks. Will check out that thread. How do I figure out the tongue weight? How do I know how much weight all my stuff weighs - I mean to say we do have a lot of stuff we like to bring with us how do I know when I've reached the limit?
  4. Apr 23, 2022 at 5:52 PM
    rimfire7
    beth
    I'm thinking it is on the heavier side. What is that going to do to my transmission? How will I know if its too heavy?
  5. Apr 23, 2022 at 5:56 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    It can tow it. It won’t do it well and you will def feel it but it will do it. You’re on the upper end for this truck. An f150 etc will do the job safer, better and with room to grow. That’s all.
    safer = bigger brakes, stronger motor, stronger transmission etc etc
    rimfire7[OP] likes this.
  6. Apr 23, 2022 at 5:57 PM
    MTB58
    MTB58 Well-Known Member
    Marty
    Prescott, Az
    2022 TRD Offroad DCSB Army Green
    Redar TBC, Window Tint, 265x75x16 Wildpeak, OEM TRD LIft, Soft Tonneau Cover, RCI Full Steels Skids, RCI Sliders
    Obviously that's important also, but with two trailer axles I don't think the trailer will be an issue. There are weight ratings on the front and rear axles listed in the door jamb of the truck. It is highly-recommended not to exceed these weight limits. Generally the weight limits on the axles exceed the GVWR of the truck, in my case the axle weight ratings are 640lbs over the GVWR if the truck. Always stay under the GVWR. The weight distribution hitch helps distribute some the weight to the front axle and some to the trailer axle.
    rimfire7[QUOTED][OP] likes this.
  7. Apr 23, 2022 at 5:59 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The problem with the Tacoma is there just isn't much payload to work with.
    Read post #12 of this thread, a little long but answers all the questions:
    https://www.tacomaworld.com/threads...w-towing-capacity-works.719492/#post-25613840
  8. Apr 23, 2022 at 5:59 PM
    rimfire7
    beth
    totally agree on not pushing the speed. However, its a long way from SE Michigan to Utah, Colorado and Montana. My husband is intent on getting to the first destination directly. we take the interstates the entire way. how will my truck handle driving for 8 or 9 hours a day with the added weight of a trailer?
  9. Apr 23, 2022 at 6:00 PM
    MTB58
    Marty
    Prescott, Az
    TNtrailrider and rimfire7[OP] like this.
  10. Apr 23, 2022 at 6:05 PM
    rimfire7
    beth
    I'll check out the sway control option, I had no idea about it. Thanks. I want to upgrade my bump stops for off roading and the dunes. I didn't know they would help with towing.
  11. Apr 23, 2022 at 6:08 PM
    rimfire7
    beth
    Yeah I am concerned about hitting that top weight. We like our stuff. My husband is all about being prepared as much as possible and brings a lot of tools, equipment and parts. We drive separate he has a jeep so when we go wheeling we don't have to take turns to drive, lol. I am thinking he needs to have a lot of our stuff in his jeep when we are traveling across country
    RushT likes this.
  12. Apr 23, 2022 at 6:13 PM
    rimfire7
    beth
    Def going to get a WDH and brake controller, What is the benefit for going in S4? I use those lower gears when I am wheeling. I am concerned about the gear. We have decent amount of stuff. we go out for 15-17 days at a time. how do you determine how much stuff to bring in context of weight?
  13. Apr 23, 2022 at 6:16 PM
    rimfire7
    beth
    Everyone looks comfortable! Where do the humans go?
    Rock Lobster[QUOTED] likes this.
  14. Apr 23, 2022 at 6:18 PM
    rimfire7
    beth
    How do I know when the weight on the axels is too heavy? I know its important I just don't know how to figure that out. Do I weigh my cargo and add it up or just estimate some how?
  15. Apr 23, 2022 at 6:19 PM
    #35
    MTB58
    Marty
    Prescott, Az
    A 1,000 lbs is a lot of stuff, but yes make the jeep carry the heavy stuff. Like someone else said "fill your fresh water at Destination". You will probably have to keep just the very light stuff in the truck.
  16. Apr 23, 2022 at 6:22 PM
    #36
    MTB58
    Marty
    Prescott, Az
    Load it up and scale it. This is my Taco towing my trailer. This was mostly dry weight. I have about 460 lbs of payload left on my truck, but about 700 more lbs on my trailer.
    Chew and rimfire7[QUOTED][OP] like this.
  17. Apr 23, 2022 at 6:47 PM
    #37
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    It's still with in the trucks tow rating it will be fine. You just will not be able to race up any steep grades or do 85 mph. In my opinion you should not go faster than 65 or 70 typically when towing anything. I know I don't with my little pop-up.
    I just feel safer because it takes longer to stop and not as easy to make fast moves to avoid something. I always look ahead farther when I tow and follow others back farther too.
    TacoManOne likes this.
  18. Apr 23, 2022 at 6:51 PM
    #38
    rimfire7
    beth
    We did that once when we owned a 40' RV and was towing an Xterra. We were 1000lbs over weight. :benchpress:
  19. Apr 23, 2022 at 6:51 PM
    #39
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    When you look in the rear view mirror ?
    Ridiculous. I pull 4500-5000 easily.
    You might want to get a trailer that doesn't sway, inflate your tires, etc.
  20. Apr 23, 2022 at 6:55 PM
    #40
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It'll do it. I've pulled an 18 hour, Charleston to Fort Worth once with Taco and trailer. It wasn't fun, but it didn't hurt the truck.
    The queen bunk, of course! Dogs sleep on the full bunk. Unless it's cold, or raining, or there's noises outside, or the dogs get to the queen bunk first...
