Weak acceleration when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by SinglecabV6, May 27, 2012.
  1. May 27, 2012 at 5:51 PM
    SinglecabV6
    SinglecabV6 [OP] New Member
    Single Cab V6 4x4
    First time posting on this site so let me introduce myself,
    My name is Curtis.
    My machine is a 95 Tacoma Single Cab 4x4 3.4 5 speed.
    I searched high and low for this combo and have big plans for this cool little truck but at the moment I am dealing with something relatively minor.
    When the truck is cold it hesitates to accelerate.
    It surges a little throughout the rpm range under heavy throttle.
    In contrast I drive the truck to work everyday(34 miles) freeway. When I take the exit near the end of the trip and drive the next couple miles in stop and go city driving the truck is very powerful and accelerates beautifully. This is the only time it seems to run this well.
    I like my vehicles to be running at peak performance at all times.
    Any ideas or recommendations?
  2. May 28, 2012 at 4:02 PM
    SinglecabV6
    Single Cab V6 4x4
    UPDATE:
    I was suspicious of the problem being related to the cat so I took it off to have a look..
    What I found was that the inside of the cat is completely hollow..
    I also had a look at each of the two 02 sensors, they seemed ok..
    Perhaps the absence of a cat, or in this case one that's been hollowed out, is my problem.
    Without a functioning cat the 02 sensor behind the cat is giving the computer information it doesn't understand and its probably getting confused about how much fuel to deliver..
    The computer is programmed to operate with a functioning cat in place.. take away the cat and you take away a a link in the chain and your circle is no longer seamless...
  3. May 28, 2012 at 4:11 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    With a bad cat, you should have your check engine light on (code 420 or 430?).
    Is it on?
    Being temp related, it could be a bad, or disconnected, temp sensor.
  4. May 28, 2012 at 5:49 PM
    SinglecabV6
    Single Cab V6 4x4
    It was..
    02 sensor out of range
    I don't remember the code..
    I've reset it twice now..
    It only comes on when "lugging" in a high gear..
    Now I know why
    I've thought about the temp sensor, I'll change it just for assurance
  5. May 29, 2012 at 7:05 AM
    tan4x4
    Rick
    Folsom, CA
    There may be several temp sensors on your truck. One for coolant, maybe one for ambient air, and maybe one for intake air, one for the tranny.
    I know I have some of these on my 99 4cyl, not sure about your 95 V6.
