Weak charging system? Solved
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iitywygms, Sep 19, 2016.
  1. Sep 20, 2016 at 7:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Volts do not move. It is just a potential for current flow.
    As long as he doesn't have any huge current draws on the system he doesn't need any type of upgrade.
    robssol and Lester Lugnut like this.
  2. Sep 20, 2016 at 7:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    0.120 milliamp is good because that equals 0.00012 amperes. and when you pulled the USB Fuse and it dropped to 0.07 milliamps that is 0.00007 amperes. This is probably the clock and stereo. Your USB is not pulling any significant amount.
    What Bamatoy told you is correct, you are fine in that regard 13.3 is perfectly normal. Bamatoy knows his stuff, no reason to question his answer.
    robssol likes this.
  3. Sep 20, 2016 at 7:42 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Ohms law, I know. Electronics tech for > 40 years.
    Unless you are packing a huge stereo amplifier stock wiring is just fine. Big three is a placebo IMO. Rarely is a wiring size upgrade needed.
    We can just agree to disagree.
    03f5sp likes this.
  4. Sep 20, 2016 at 7:54 PM
    iitywygms
    iitywygms [OP] Well-Known Member
    Norcal
    4x4
    No. No I do not. Talk to BamaToy if you like.
  5. Sep 20, 2016 at 7:56 PM
    iitywygms
    Norcal
    4x4
    Thank you. I think the battery I have is just not the best. Next time I park it long term I will just put a battery tender on it.
    Thanks to everyone for your help/
  6. Sep 20, 2016 at 8:00 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    if you had it on mA and it read .120 that is essentially nothing. 1mA will drain a battery in about 40,000 hours. You are pulling just over .1mA, which will extend that to 400,000 hours. I don't think that is a problem. If you want to confirm, and have a resistor anywhere around, connect the resistor in parallel with the mA meter and connect a probe to the battery +, other probe to the resistor, and the other end of the resistor to battery -.
    Ohm's law says current = volts / resistance. Since we know that volts will be about 12.5, if you can dig up a 100 ohm resistor, current should be 12.5 / 100 = .125a, or 125 mA. NOT .125 mA. That would let you verify that the meter is reading what you think.
    If you set it to read amps, you should get .125A, same as 125 mA.
    iitywygms[QUOTED][OP] likes this.
  7. Sep 20, 2016 at 10:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Oh, so I should just throw Ohms Law out the window.
    Or maybe you could educate yourself on what really goes on with electrical circuits and how they work.
    How did you measure these miraculous improvements over stock cables?
    What do you think regulates / determines the current draw on the battery?
    How did your previous wiring fail with the stock wiring, what caused it, be specific?
    How can Tacomas and 4Runners last for hundreds of thousands of trouble free miles with defective wiring?
    robssol, Larzzzz, Crom and 1 other person like this.
  8. Sep 21, 2016 at 5:39 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    there is absolutely no truth that the wiring system (charging system does not ) have the capacity to run a normal vehicle. Like JimmyH says that parasitic load is nothing. I have a 1998 corvette that has a parasitic load of 35ma because of the security system, and the battery lasts for weeks.
    Its like the monster speaker wires nonsense.
  9. Sep 21, 2016 at 8:51 AM
    RobertHyatt
    Robert
    Birmingham AL
    This is actually a pretty strange discussion. An 8 gauge wire can carry OVER 150 amps at 12v. And it climbs quickly. 12ga wire can carry 60amps at 12vdc continuously. 10ga jumps this to 100a. 8ga to 150. It is not linear because it is proportional to the cross-section of the wire. 6ga wire goes over 200 amps. The stock wiring will carry most anything you can put through it. A starter can draw 300 amps and that won't melt the cable. If the motor locks or can't turn over (say a manual transmission in low gear) that starter can draw over 500 amps.
    Obviously the cable to the starter and from battery to ground are up to this task easily. I think worrying about the cables is a waste.
    CurtB likes this.
  10. Sep 21, 2016 at 9:49 AM
    iitywygms
    Norcal
    4x4
    My original intent of asking this question was to understand why my battery died after sitting for 8 days.
    The topic has now turned to how big should the wires be. Which is irrelevant to what I had originally asked.
    I completely understand that the wire size has nothing to do with my issue.
    This idea that the size of the cables caused my battery drain is funny.
    Comparable to this.
    http://gizmodo.com/363154/audiophile-deathmatch-monster-cables-vs-a-coat-hanger
    Jimmyh likes this.
  11. Sep 21, 2016 at 12:07 PM
    topcathr
    2015 limited
    I think RobertH has a good idea pull fuses till it drops then you will get an idea where the drain is coming from. Sometimes a alternator can have a slight leak on a diode that can also show up as a draw.
  12. Sep 21, 2016 at 2:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You also have voltage losses even with your massive upgrade. Every electrical circuit has voltage drops esp at every mechanical connection. Remember Ohms Law said it was true.
    I said in my first post about this:
    "As long as he doesn't have any huge current draws on the system he doesn't need any type of upgrade." and " Unless you are packing a huge stereo amplifier stock wiring is just fine. Big three is a placebo IMO. Rarely is a wiring size upgrade needed."
    When you say you found out the hard way, tell us what happened? I see you never answered my questions above.
  13. Sep 21, 2016 at 2:11 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    OP, sorry about the thread jack.
  14. Sep 21, 2016 at 2:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I see you still ignore my simple questions. and from the bolded above I see why. You have no clue about electrical principles and Ohms Law. You do have voltage drops regardless.
    I am also done I think my point was made, and confirmed.
  15. Sep 21, 2016 at 2:36 PM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    This my last comment as I couldn't let this go.
    1.) I don't have to prove anything. It was done years ago and is published as Ohms Law. Look it up it's enlightening.
    2.) I have been an Automation Electronics Technician for greater than 40 years.
    3.) 22 of those years is in the automotive manufacturing industry.
    I have some idea what I am talking about.
    Yes, that does in fact trump your measly few hours researching "the big 3".
  16. Sep 21, 2016 at 3:01 PM
    #36
    iitywygms
    Norcal
    4x4
  17. Sep 21, 2016 at 3:24 PM
    #37
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    A have to LoL at E dick.
    And both of you are right. A big amp draw needs bigger wire. And no matter what there is always a loss thru wiring, no matter what.
    TXpro4X4 likes this.
  18. Sep 21, 2016 at 3:27 PM
    #38
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes it is called resistance
  19. Sep 22, 2016 at 12:44 AM
    #39
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Why is this even a thread? You're getting 13.2v at idle with full load plus extra accessories.. What is your concern? Judging by the given info, everything is 100%. End of thread.. I don't claim to be an expert but I am a motorcycle technician and am speaking from experience, not misinformed internet here say.
  20. Sep 22, 2016 at 2:04 AM
    #40
    Jimmyh
    SC
    2012 Prerunner SR5
