Weak Hot Start
Discussion in '4 Cylinder' started by 2.7taco, Oct 21, 2016.
  1. Jan 15, 2017 at 2:56 PM
    #61
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Keep us posted.
    2.7taco[OP] likes this.
  2. Jan 15, 2017 at 3:06 PM
    #62
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Will do.
    Sent some photos to a good friend who is an old school racer/mechanic he said the same cylinders 1, 3 and 4 are a little lean and cylinder 1 and cylinder 3 are leaner than 4.
    I really hope ordering 4 new injectors fixes the lean condition. When I do the swap I will be pulling the positive cable on the battery in hopes of completely resetting the ECM.
    If I can I will try and pull the O2 and the wide band O2 to see their condition.
    The weather around here has just taken a nose dive so any additional work will be when things dry up.
  3. Jan 15, 2017 at 3:11 PM
    #63
    2.7taco
    Texas
    The infrared camera shows no abnormal heat soaking on the coil packs after 30 minutes of sitting. Also the exhaust manifold looks consistently warm from cylinders 1 to cylinders 4 which means my EGT is fairly balanced.
    Toyko Joe likes this.
  4. Jan 16, 2017 at 2:28 PM
    #64
    2.7taco
    Texas
    Well chit.
    So today was the beginning of some reckless testing. Seems I've got pre-ignition on all 4 cylinders or the system is running very lean. NGK spark plugs is having a look first thing in the morning.
    Mini rant: Sadly this truck has been to the dealership and they keep saying all is well. I call BS but again no one at any Toyota dealership cares about their customers.
    Rant off.
    This may be the entire reason for my starting difficulty. Timing too advanced but why the truck won't throw a single code is beyond me. If the timing chain was loose besides the noise unloaded I would think the timing would go further retarded. My guess is tight valves. Damn shim under bucket design will make life absolutely hell to check valves and even reset them.
  5. Jan 20, 2017 at 5:50 PM
    #65
    2.7taco
    Texas
    Straight from NGK. Combustion too lean.
    Got a new wide band O2 and narrow band O2 to install when the weather cooperates. Still hunting down Xgauge codes for long term and short term fuel trims. What I have seems a bit off as the values fluctuate entirely too much. A/F ratio stays solid at 14.7 unless I blip the throttle then it swings to 13.6 for just a moment. Long term trim showed a bouncy -3 and Short term trim showed a bouncy 1. Never stayed solid. Ignition timing measurement is really off the wall. At WOT it was 43!
  6. Jan 20, 2017 at 10:40 PM
    #66
    2.7taco
    Texas
    Well after looking at things even more I now have an official answer on the spark plugs. The plugs shoe slightly lean with a little ash deposits from oil burn off. All 4 cylinders are nearly equal.
    Now back to hunting down the starting issue. More testing to come.
  7. Feb 2, 2017 at 7:47 AM
    #67
    2.7taco
    Texas
    SPARK KNOCK!!! After starting and warming the engine for a few minutes I left to go pick up an oil filter for my significant others truck. When I throttled up to cross the road all it did was sputter and knock. So the fuel is definitely not making it to the cylinders under load. At idle it's fine and light throttle it's perfect but if you throttle up it knocks. The AFR went from 14.6 at idle to 13.9 then all of a sudden it started the knock which was at WOT and the AFR was 14.8. Damn thing went way lean.
    Now I know I need a knock sensor (it should have tripped and flashed the CEL) and 4 new injectors. Freaking truck is a nightmare. Some days I really wish Toyota would program their ECM better.
  8. Feb 2, 2017 at 7:53 AM
    #68
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    so what are you thinking a bad fuel pump?
  9. Feb 2, 2017 at 7:55 AM
    #69
    2.7taco
    Texas
    Not the fuel pump has plenty of output. 41-42 PSI at the fuel rail. Lean mix can be from plugged injectors or maverick air (non-metered air).
  10. Feb 2, 2017 at 7:58 AM
    #70
    Toyko Joe
    Toyko Joe Here for the pictures
    It sounds like advanced timing again by what you're describing... but I am not an engine expert, I just dabble in it. -Or- Leaking intake manifold. Have you tried the old Starter fluid test? Spray down small areas around the intake manifold seams while your engine is idling, your engine will rev when the spray gets sucked in through the air gap...
  11. Feb 2, 2017 at 12:23 PM
    #71
    2.7taco
    Texas
    I've been into the truck so much it may be possible but unlikely that it has maverick air entering. I would rather use propane but no I haven't done the testing yet. Been a busy few days.
    It could be timing but the plugs are on the lean side.
  12. Feb 5, 2017 at 8:25 AM
    #72
    2.7taco
    Texas
    No maverick air entering any intake plumbing. So this time I think I got a break in have been looking for. I opened the oil cap and took a sniff and would you guess what it reeked of. GASOLINE IN MY OIL! This is the first time that has happened. 4 injectors on the way.
    98tacoma27 likes this.
  13. Feb 9, 2017 at 4:51 PM
    #73
    2.7taco
    Texas
    4 new injectors dropped in and an inline fuel filter tied in. The fuel filter may be temporary but during the process the fuel pipe coming from the tank and to the rubber line had the coating come off! Hopefully that will not effect sealing. Worse case scenario is buy a new rubber fuel line with a new o-ring that hasn't settled. ECM reset currently in progress. I will know more in an hour or so.
    wilcam47 likes this.
  14. Feb 9, 2017 at 6:49 PM
    #74
    2.7taco
    Texas
    So far so good. Reconnected the battery and it fired up like a champ. We will see how things progress over time. I will try to update this thread after I see how the truck starts layer on tonight. Idle is smoother and part throttle acceleration has improved some. ECM is still in training mode and I need to get it on the interstate for the last if the fuel trim and table adjustments.
  15. Feb 10, 2017 at 8:18 AM
    #75
    98tacoma27
    Ben
    Not Beech Creek
    So are you thinking leaking injector(s)?
  16. Feb 10, 2017 at 9:17 AM
    #76
    2.7taco
    Texas
    They did not leak until here recently. Before I would be running lean especially at any RPM above 3000. Plugs were white showing high combustion temps. Chances are the injectors were plugging and finally a pintle quit seating.
    The giveaway that the injectors were leaking at the end was the oil smelled like my gas tank.
    Still in the drive learn mode for the ECM. Extended idle, 0-45 light throttle, 0-45 moderate throttle, 0-45 heavy throttle, 45-25 coast, several transient acceleration runs at various speeds and all that remains is the highway speed runs constant at 55 and then at 70.
  17. Feb 10, 2017 at 4:40 PM
    #77
    2.7taco
    Texas
    Well bad news. I must have gotten some bad injectors. Black smoke from the tail pipe.
  18. Feb 10, 2017 at 4:41 PM
    #78
    koditten
    Kirk
    Central Michigan
    Man! You can't catch a break!
  19. Feb 10, 2017 at 4:46 PM
    #79
    2.7taco
    Texas
    No kidding. Just left five0 Motor sports a voice mail. Hopefully they respond with an answer. The injectors come with a 3 year warranty.
  20. Feb 10, 2017 at 5:38 PM
    #80
    2.7taco
    Texas
    I'm going to unplug the battery for several hours and then again overnight and see if another reset helps. I've been told to unplug the positive cable and also the negative and tape them together causing them to short and drain the ECM.
