Weak HVAC flow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Logger, Sep 2, 2024.
  1. Sep 2, 2024 at 6:17 PM
    Logger
    Logger [OP] out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    I’ve noticed what seems to be weak air flow in heat and AC modes. My fan not only chirps but hums in high. On full front vent with recirc or fresh air the air velocity seems to be the same (weak).
    I feel like it should be much better. Cabin filter is new. I also experienced the resistor crapping out until I moved the connector. I ordered a new one. Yet to install.
    Could a failing blower motor cause weak air flow?
  2. Sep 2, 2024 at 9:07 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Could be a bad blower. Have you ever cleaned your evaporator? Toyota sells or used to sell a kit, you spray a can of expanding cleaning foam into the ac drip line. Let it do its thing for like 5-10 minutes then drain it out. It also has an after treatment you spray into the blower with the fan on to help make the vents smell better after. I usually do mine every few years since a lot of dirt gets past my cabin filters.
    Edit: link to the toyota kit
    https://autoparts.toyota.com/products/product/ac-refresher-kit-00289acrkt
    Logger[QUOTED][OP] likes this.
  3. Sep 3, 2024 at 10:34 AM
    TacoTuesday1
    FL
    Blower motors go bad. So does the resistor.
    KeiRei said put a KN washable cabin filter for more flow so I did that.
    Threw a blower motor at it. Why not.
    new one looks different. That means there’s a design improvement. Which is a good thing.
    this looks good. As in the drip line at the frame many of us have relocated downwards off the frame? Hopefully that can is strong enough to actually get upward into the evap through that hose.
    Logger[OP] likes this.
  4. Sep 3, 2024 at 10:43 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The resistor is by-passed on High.
    If the air flow is still weak on high, it's the blower motor or fan speed switch.
    The fan speed switch typically only fails on High speed setting. It's super easy to pop out, it the High speed pin isn't burnt, I'd feel safe calling it a blower motor issue.
    Also, if the resistor is giving you issues, might as well replace it too.
    Logger[OP] and wilcam47 like this.
  5. Sep 3, 2024 at 10:54 AM
    CajunCrawler
    CajunCrawler Well-Known Member
    Cooper
    2015 Black Tacoma
    JL audio speakers, amp, sub Black method 305 wheels 285/75r16 BFG KM3 Bilstein 6112/5160 JBA uca total chaos diff drop
    I had the same issue my high blast would work but nothing else it was a solenoid it should be about $50 and the are plenty of forms about them.
    wilcam47 likes this.
  6. Sep 3, 2024 at 11:01 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Time to recharge your system? I recharged the A/C system on my RV. Picked up a couple of cans from Harbor Freight tools. So easy a retired Teacher could do it!
  7. Sep 3, 2024 at 12:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just, No.
    The AC Charge has nothing to do with air flow.
    Too Stroked, wilcam47 and TireFire like this.
  8. Sep 3, 2024 at 12:35 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Until the evaporator coil ices up and cuts the air flow.....................
    ScrippsRanch67 likes this.
  9. Sep 3, 2024 at 1:18 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my resistor went out and then the blower failed soon after
    I feel that the resistor went because the blower did in my case
  10. Sep 3, 2024 at 2:01 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The blower air flow cools the resistor. No flow no cooling and resistor burns out.
    knottyrope[QUOTED] likes this.
  11. Sep 3, 2024 at 2:51 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  12. Sep 3, 2024 at 3:05 PM
    hamstur
    hamstur Well-Known Member
    Phoenix AZ
    2013 DCSB 4x4 TRD O/R MGM
    Wet Okole full F/R, Grillcraft, Avid Offroad sliders
    I had an issue on my Gen2 where high fan speed would work, but got very weak or non-existant on other speeds. Sharing in the low chance it's related.
    There's a quick-connect wire in the passenger footwell that controls fan speed. I inadvertently discovered it to be the issue because my sunshade slipped down there and bumped it, and my fan suddenly started working again. I grabbed the shade and it stopped. Jabbed around and it worked, etc. Ended up checking all the connectors down there, and sure enough one was a little loose. Electrical taped it up and never had the problem again.
  13. Sep 4, 2024 at 11:57 AM
    Logger
    Sam
    Thank you for taking the time to add a link.
    I have not cleaned the evaporator. I will give the kit a whirl and see.
    I don't expect the vents to blow my hair back, but the output just seems low and virtually unchanged across all speeds. I may also look into replacing the blower motor seeing as it hums and chirps.
