Weak Qi charger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 30, 2017.
  1. Mar 30, 2017 at 8:30 AM
    Totall4285
    Totall4285 [OP] Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Anybody else have problems with the qi wireless charger not charging through cell phone case. I don't have a really bully case or anything and my wireless charger at home works just fine with case on. Any fixes to this or do I just have to live with it?
    Maadanchik likes this.
  2. Mar 30, 2017 at 8:37 AM
    kskm497
    kskm497 Well-Known Member
    Joshu
    2016 Super White Tacoma TRD Sport
    I have had the same problem for quite some time, I would love to know a workaround as well. I literally spent about two hours at Verizon, Best Buy, and a local phone store...I went to Verizon last, explained to the guy my situation...so, they at least were nice enough to not make me pay for cases, try them out in the parking lot, then return them. He and I went out there together and tried several until we found the best one for my particular phone. The TUMI case was the best for my phone(galaxy note 5).
    However, I still have issues hitting a bump, a turn, anything...it will pop on and off all the time, so, I quit using it. If they would install three coils instead of two, there would be no issue. I did a little research and I'm thinking that was the difference between the wireless charging systems gen 1 and gen 2. One simple coil for cases...now it is standard.
    I would love to know if anyone has found a workaround for this as well. Would love to actually use it.
  3. Mar 30, 2017 at 9:25 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I have a Driod Turbo with an Incipio case that worked perfectly in 2 '16 Chevy full size trucks. In my Taco, my phone has to be in the right place and with the case on it will get warmer than usual. It will not get a full charge.
  4. Mar 30, 2017 at 9:46 AM
    jLEE028
    jLEE028 Well-Known Member
    MKE
    same issue here. i have the nexus 6 with a supcase. it will show as its charging, then 20-30 seconds later, shows not charging in an endless loop. my phone has a curved back so it doesn't sit flat and i think that plays a part cause it moves around a lot. but once i take off the case, it charges fine. not a big deal for me since i'm looking for a new phone anyways.
  5. Mar 30, 2017 at 9:52 AM
    kskm497
    Joshu
    Yeah I honestly still have the same problem with the case off...because they are plastic it slides around corners...it's like it has to be perfectly center for it to charge.
    I'm sure you have heard the new S8's are coming out...I have to wait for an upgrade, but they are looking pretty nice! :taco:
  6. Mar 30, 2017 at 9:55 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have noting to actually contribute to this thread, but I would like to point out that I have jumped on the hype train for this phone. So ready to upgrade my S6
    shakerhood and kskm497[QUOTED] like this.
  7. Mar 30, 2017 at 10:00 AM
    jLEE028
    MKE
    yeah, i was never really into samsung, but you can't deny the how great their phones are. i like big phablets, so that s8+ is worth a look. i'm partial to the google phones which are simple and no bloatware. hopefully google gets it right with the next pixel.
    kskm497[QUOTED] likes this.
  8. Mar 30, 2017 at 10:02 AM
    growyourmind86
    growyourmind86 Well-Known Member
    2017 trd Tacoma
    I just keep it old fashion plug it in with the cable. The wireless charging never really made life easier, my phone has to be on the pad perfect and then takes a few to start charging Have no case on it. I did see a new Samsung fast charge pad in the store and it was way better than the first ones that came out, but that tech is not in the taco. The taco one takes a long time to charge so unless you go on a long drive you do not get much charge. I like the quick charge plug it charges fast.
  9. Mar 30, 2017 at 10:11 AM
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    It's more a Qi limitation than anything, I actually had better experience w/ the one in the Taco than the bases I have at home. Stopped using it in the house because if it isn't sitting just right it goes on/off and if the battery is below 10% on my phone it won't take a charge (no clue why). It's all about placement and cases are going to impact that. I changed phones and now don't have Qi anymore anyway :\
  10. Mar 30, 2017 at 10:17 AM
    paradox4286
    paradox4286 Well-Known Member
    San Antonio, TX
    17 TRDOR DCSB P/T JBL
  11. Mar 30, 2017 at 10:26 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    Works great with my body glove case on my Galaxy S6. I do have to place it in the sweet spot with for me is shifted to the left as far as possible. Its a really grippy case so it doesn't slide around on the charger.
  12. Mar 30, 2017 at 11:10 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Ha, why yes it does! Keeps the phone visible and at least for me I always seemed to forget it when it was in the cubby.
    FYI, with my iphone7 in a Qi case I get around 14-15% battery gain per half hour whether in the cubby or on the Qi charger mount. That quite enough for my needs. I look to it more for maintaining charge than to restore a dead phone.
  13. Mar 30, 2017 at 11:12 AM
    gpb
    Atlanta
    Indeed, this is very important. The coil is typically under two inches diameter and the further it's misaligned with the receiver patch the less efficient the charging.
  14. Mar 30, 2017 at 11:34 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Qi chargers generally need to be within a very close proximity. A case will usually hinder this ability because of thickness.
  15. Mar 30, 2017 at 12:07 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Still waiting on the S7 to go on sale to buy one.
  16. Mar 30, 2017 at 1:56 PM
    TripleEight
    TripleEight Well-Known Member
    2016 Tacoma TRD Off Road DCSB Gray
    I bought a Qi charging adapter for my Sony Xperia Z2 and could not get it to charge my phone in the truck, and I'm not even using a case.
  17. Mar 30, 2017 at 2:52 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    The Qi charger is weak. It doesnt matter if I have the case on or off. This wireless charging feature in these trucks is more of a "maintainer" than a charger. Of course the Note 5 has a larger sized battery. If you have a smaller smart phone that allows wireless charging it might work better.
    shakerhood and LivinOnEdge like this.
  18. Mar 30, 2017 at 2:57 PM
    CXP8PRO
    CXP8PRO Well-Known Member
    Andrew A
    17' TRD PRO Super White
    hate the qi charger in our tacos. Takes too damn long. I just plug in my phone and put it on top of the qi charger location and charge it the old fashion way.
    paulindsm and LivinOnEdge like this.
  19. Mar 30, 2017 at 3:01 PM
    LivinOnEdge
    Land of The Lost
    I've never used the one in the Tacoma because I have an Iphone but I've used it for other devices and they charge fine. Must be one of the things they decided not to spend the extra few bucks to engineer any better. From what it sounds like, your right, it's probably only good for keeping your phone from losing battery if it's just sitting idle.
  20. Mar 30, 2017 at 3:02 PM
    smitty99
    Scottsdale
    I think the wireless charging "coils" are just weak. Probably worried about the things overheating and catching something on fire a la the Galaxy Note 7.
