Weak start
Discussion in '1st Gen. Tacomas (1995-2004)' started by cadman33619, Dec 19, 2022.
  1. Dec 19, 2022 at 8:02 AM
    cadman33619
    cadman33619 [OP] Well-Known Member
    for a while now i've had an issue with weak starting.... or slow starting. The battery is 7 mo old and the alternator was changed just over a year ago. Both were changed because of the weak starting but did not help. its even worse on cold days.. barely starts (i live in Tampa so there aren't many of those) I recently did a tune up on my own that included: plugs, coil packs, PCV, air filter, all 3 belts. still have the same issue (although i now have a noticeable boost is power). Last week i cleaned the battery terminals that were covered with corrosion.... but that didn't help.
    what else can i do to fix this issue?
    2004 prerunner 4cyl 189k mi
    six5crèéd likes this.
  2. Dec 19, 2022 at 8:03 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    New cables, and possibly a new starter.
    Bivouac and wilcam47 like this.
  3. Dec 19, 2022 at 8:03 AM
    gclyne
    gclyne Well-Known Member
    Grant
    Indiana
    2004 TRD Off-Road- 3.4L
    When was your starter last replaced?
    wilcam47 likes this.
  4. Dec 19, 2022 at 8:03 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Starter
  5. Dec 19, 2022 at 8:26 AM
    cadman33619
    i'll have to get you the exact date... but it was replaced earlier this year because it failed completely... came out one morning and would not start. got a pipe and gave the starter a few taps and started right up. replaced it a few days later.
  6. Dec 19, 2022 at 8:32 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you saying it sounds like it's cranking slower than normal?
    Does the battery voltage drop below 10-10.5 volts during cranking, if yes the battery is weak
    YouTube some videos on how to perform voltage drop tests across the battery cables (including ground cables) between battery/starter/frame/etc. This will identify a poor connection at the frame or block
    Sounds like the starter is fairly new, but sometimes they can bind up internally. Electrically fine but the bushings/shaft won't want to spin, like a lack of grease or mechanical issue
  7. Dec 19, 2022 at 8:36 AM
    wilcam47
    Will
    Bourbon state
    Was it aftermarket or OEM starter?
    Philip* and Bivouac like this.
  8. Dec 19, 2022 at 8:43 AM
    cadman33619
    cranking slower than normal... yes. aftermarket starter... from Advanced Auto parts.
    i'll do the voltage drop tests later today. Sounds like a kewl thing to learn.
  9. Dec 19, 2022 at 8:45 AM
    wilcam47
    Will
    Bourbon state
    Id still suspect starter but could be any if the three, starter, alternator or battery
  10. Dec 19, 2022 at 1:23 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Quality is so hit or miss on remanufactured Electrical Parts . I have far to many that failed out of the box
    Local Auto Electrical shop or Denso Reman from a Toyota Parts vendor.
    Past time to upgrade the battery cables.
    Good Luck!
  11. Dec 29, 2022 at 12:45 PM
    cadman33619
    tested the battery using method i saw on youtube. with truck off... i get 12.68A (after leaving headlights on for 2 min). left leads connected and stared the truck... i get 14.63. seems to be good. I removed the terminals and cleaned them with a terminal cleaner that has wire bristles. They're making excellent contact now. But im still getting a slow crank. looks like next step is to test the alternator or starter.
  12. Dec 29, 2022 at 3:06 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    My 97 4 cyl is the same way, I’ve replaced everything but the cables themselves, and even bought the “cold climate” starter which supposedly has more torque and it still sounds like it struggles to crank over. Even during the warmer months.
  13. Dec 29, 2022 at 7:14 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    You left out ignition switch.........
    nothing lasts forever......
    pretty much only thing in ignition/coil branch you havnt replaced.....
    I think a bad/weak coil (non-oem one) caused mine to give up the ghost......
    I even keep a $20 generic Beck/Arnley one in my glovebox now......just in case.....
    that switch plugs right into the harness of a ton toyota models.......its the mounting holes that give the different part #'s........you could steal any toy.....in less than 30 sec........the power of just one plug.......
    wilcam47[QUOTED] likes this.
  14. Dec 29, 2022 at 7:40 PM
    O'Silver_Taco
    MD
    Also figured on my 26yr old truck.....
    It was a good ideal to run a braided ground direct from neg post to intake plenum (computer mount) for more reliable ground to fuel both the 30a AM2 branch firing the coils.....and the 40a AM1 branch (injectors) running pretty much everything else....
    Relying on a 25yr old body ground seemed crazy to me.....
