Weak tailgate reinforcement solution
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RelentlessFab, Mar 4, 2009.
  1. Mar 4, 2009 at 1:46 PM
    RelentlessFab
    RelentlessFab [OP] Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    OP updated, see below.
    This replaces the entire factory inside and top plastic covers with tough 1/8" aluminum. I regularly load 400-600lb brush mowers, atvs and sections of logs, etc. into my truck and this has yet to fail me!
    Hope this helps those of you that are concerned with the strength(or lack thereof:rolleyes:) of the factory tailgate and want to do something about it before bending this costly item!
    THIS ITEM CAN BE PURCHASED ON MY WEBSITE
    http://www.relentlessfabrication.us/online-store.php#!/~/product/category=3368787&id=14437186
  2. Mar 4, 2009 at 1:49 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Thats a damn good idea thanks. I already bent one its like 1000-1200 from the dealer.
  3. Mar 4, 2009 at 2:00 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Now if you only lived close I would have you make me one.........:D
    :thumbsup: NICE GOING
  4. Mar 4, 2009 at 2:02 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Looks good! :D
  5. Mar 4, 2009 at 2:06 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    whats the total cost of that?
  6. Mar 4, 2009 at 2:11 PM
    RelentlessFab
    Eric
    Probably about $60 of metal + the labor, maybe an hour of cutting, bending, and drilling/installing.
  7. Mar 4, 2009 at 5:37 PM
    Marazzito
    Marazzito Well-Known Member
    Dublin, CA
    07 DC TRD Off-Road 4x4
    TRD Exhaust, AFE Cold Air Intake, URD Short Shifter, OME 886 HD Lift OME Rear Springs With XL... TRD Supercharger Coming Soon.
    You should make them for fellow TW members and ship them. I bet you could make some decent money, there is a high demand for a stronger tailgate. I would certainly consider purchasing one.
  8. Mar 4, 2009 at 6:34 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Nice. Would be perfect Line X'd.
  9. Mar 4, 2009 at 7:39 PM
    RelentlessFab
    Eric
    I may be able to do that in the future...... stay posted.
  10. Mar 4, 2009 at 7:55 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    So I was thinking of just using 16 gauge steel (or something equivelent) and just replacing the lower portion (not the top rail). Do you think the top gives you any extra support???
  11. Mar 4, 2009 at 8:05 PM
    RelentlessFab
    Eric
    The top probably adds like 95% of the strength due to the bends in the sheet. A flat sheet of metal will bend easily, but throw a bend across and it makes it rigid. Those are totally necessary to give it any additional strength over the factory cover.
  12. Mar 4, 2009 at 8:17 PM
    TacoNut
    Adam
    Denver, Co
    that's what I was afraid of...
    looks like that's what i'll be doing, Thx for the diagrams!
  13. Mar 4, 2009 at 9:49 PM
    RelentlessFab
    Eric
    No problem, but if you're just going to use steel, you might note that that 'jogged bend' near the top of the gate is only about a 1/4 x 1/4 drop, the 3/8 was for a little extra clearance since thicker metal cant quite bend like that too easily, though your steel probably can.
  14. Mar 5, 2009 at 3:23 AM
    beechcraft
    beechcraft Member
    NJ
    06 AC 4x4 TRD-S
    I could definitely use one of these.. Thanks for posting the drawing, I'm gonna look into having one made up..
    ..but If you end up getting these made I'd take one undrilled, to save labor on your end. I recently got a 2nd gen and I'll have 300 lbs+ on the gate fairly regularly.
    Also, I realize the around-the-top bend is adding a little more rigidity, but would having just 1/2" or so of material there instead of 2.25" compromise much of it's integrity? I'd rather have something a bit more low-profile..
    I had the infamous 3 dimples on my 1st gen taco early on.. The dimples were always annoying but now seems quite a bit easier to live with than this ridiculous bent tailgate issue. ugh.
  15. Mar 5, 2009 at 6:49 AM
    TacoNut
    Adam
    Denver, Co
    Yea, I'll have to look into everything a little more.... the only thing keeping me from doing the top piece as well was that I could do the rest by my self. We'll see what happens and I'll keep you posted when it does.
  16. Mar 5, 2009 at 6:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    FWIW, A peice of angle iron installed in the top of the tailgate does wonders.
  17. Mar 5, 2009 at 6:53 AM
    TacoNut
    Adam
    Denver, Co
    another possibility
  18. Mar 5, 2009 at 6:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    being as it is attached under the top of the tailgate, and inside, the tailgate looks stock.
  19. Mar 5, 2009 at 7:01 AM
    TacoNut
    Adam
    Denver, Co
    I would still replace the inside piece with steel of aluminum.... The whole reason I started thinking about this was to have a more durable surface... The strength is an added bonus.
  20. Mar 5, 2009 at 3:53 PM
    Fredneck
    Fredneck Active Member
    Wyoming
    09 2.7L Tacoma
    BONE STOCK for now
    Relentless, If you ever start to make these I'd be real interested in getting one.
