Weak windshield sprayer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jbrewster, Nov 23, 2011.
  1. Nov 23, 2011 at 7:48 PM
    jbrewster
    jbrewster [OP] Active Member
    06 Reg. Cab 4x4 SR5
    Hi,
    New here. Recently got an 06 Reg cab 4x4 sr5. I love it! (had a 96 taco before that, and an 84 before that)
    My windshield washers are very weak. Just wondering if this is normal for the 2nd gen taco, or if mine has some sort of problem. I have -40 F fluid in the reservoir, so I don't think freezing is the problem. The spray comes up to maybe 1/4th height on the windshield, and it takes a few wipes of the blades to even get the whole thing wet. Any thoughts?
    I drilled an extra hole in the lid of the reservoir, thinking that perhaps it was pulling a vacuum, but that has not helped the problem.
  2. Nov 23, 2011 at 7:54 PM
    jbrewster
    06 Reg. Cab 4x4 SR5
    yeah, i was wondering about that. what is a good way to clean those little bastards? I've heard that using a pin or similar is "not advised"
  3. Nov 23, 2011 at 7:55 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    +1 Maybe put a little vinegar or jewelry cleaner in there to flush out some possible corrosion. Your nozzles should spray the entire windshield with authority.
  4. Nov 23, 2011 at 7:56 PM
    jbrewster
    06 Reg. Cab 4x4 SR5
    that's a good idea...i will try that and see if it helps. I'm a little wary of sticking a pin in there
  5. Nov 23, 2011 at 8:00 PM
    KAWAIANIANI
    KAWAIANIANI Well-Known Member
    TRD BLACKED OUT
    Weather tech stone deflector, Craven speed stubby antennae,DTLT and rear O2 Sims, URD Y pipe, 40 series flowmaster w/ 3" piping. Urd maf calibrator, TRD supercharger, TRD CAI.
    x3 especially if the truck used to get waxed alot it can get in there and clog it up.
  6. Nov 23, 2011 at 8:08 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Mine had clogged tubes. I took an air compresser and blew out the tubes and they worked perfectly after that.
  7. Nov 23, 2011 at 8:13 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Wonder if it's feasible to mount a more powerful pump, like those used in European headlight washers?
  8. Nov 23, 2011 at 8:15 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Just a thought, they do come out of the hood with a bit o' work, but can you soak them in a solution like CLR, which removes everything from calcium, rust lime deposits, or like they said above, compressed air would work, I just wish they were more of a mist rather than a jet of water like on my 1999, hmmm, maybe I need to do some work on mine.......
  9. Nov 23, 2011 at 8:18 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    That's what i get for being lazy and not reading :der:
  10. Nov 24, 2011 at 2:04 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Actually, if you examine the washer hose where it travels under the hood, but still in the engine compartment just below the windshield. You will probably see the point of contact where the hood gasket and the engine compartment gasket both compress the washer hose when your hood is closed. It's getting pinched off. Simple fix; cut a channel in the rubber gasket the width of the washer hose in the gasket right below it. Now the washer hose will sit in that channel and not get compressed when the hood is closed. I found this fix for a guy I work with that was complaining of the same thing and noticed that when we were looking at it. I've passed that tip on to six other guys I work with. All are happy now.
    Take a look, you'll see what I'm talking about.
  11. Nov 24, 2011 at 6:48 AM
    jbrewster
    06 Reg. Cab 4x4 SR5
    wow. thanks for the tips. I will definitely check out the hose/hood junction.
    thanks!
  12. Nov 24, 2011 at 2:03 PM
    jbrewster
    06 Reg. Cab 4x4 SR5
    for the win! i looked at the hose at this point and it was totally mashed-- you could also see it's imprint in the hood gasket. I cut out a little channel for it and it is 100x better. thanks! i'll post some pictures of it later if anybody is confused.
  13. Nov 24, 2011 at 2:08 PM
    Johns Taco
    Albuquerque, NM
    Glad you got it fixed! :)
  14. Nov 24, 2011 at 3:43 PM
    BigBiscuit
    Mass.
    Glad it worked out for you. :D
  15. Nov 24, 2011 at 5:13 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I'm gonna have to check this out. Wasn't sure why some days would be awesome spray mode and others are just wet the whistle. Thanks for the tip!
  16. Dec 6, 2011 at 3:39 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    I'm gonna have to take a look at this. On the way to work this morning I tried to wash the road spray off and I barely saw a trickle come out of the driver side nozzle. Passenger side didn't do anything. Stopped for gas and checked the reservoir-half full. I did have my hood up this weekend while replacing my front bumper, I'll bet the hose got crimped somewhere. Hopefully its not the pump.
  17. Nov 16, 2012 at 1:39 PM
    over60
    over60 "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I've got the same weak spray issue.... Thanx a heap guys... I'll check out the hoses tomorrow... sounds like mine is likely squashed also... I think I'd rather run the squirter hose thru a piece of stronger plastic hose than cut my weather stripping, but I'll see if I have that problem and report back tomorrow.....
    Over60
  18. Jan 16, 2013 at 4:29 PM
    over60
    Muskoka, Ontario
    Hey, I forgot to report back on this issue.... Sorry guys.
    My washer hose was squished where it goes over the weatherstripping and then on into the hood and squirter nozzles.... I just placed a real hard piece of plastic tubing over the rubber hose at that location and all is well again...
    Hope this helps..
    Over
