Wear inside 7.5 clamshell. Need help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ktaco, Dec 23, 2016.
  1. Dec 23, 2016 at 12:00 PM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    This is not the diff that's currently on my truck. It's a spare that I have that I am going to be installing an Aussie locker into in a few weeks. I wanted to strip it all down to get ready for the install and to clean out all the gear oil before bringing it into the house.
    Now this stuff is all new to me and it's the first time I've ever opened one of these. There is a pretty obvious wear mark into the inside of the clam shell from what I can only assume is the outside of the ring gear. 90 degrees from that on the other side of the pinion gear there is also some wear but just a small spot.
    Like I said I'm a newb to this but I assume this isn't normal wear over time? What would be the cause, bad carrier bearings?
  2. Dec 23, 2016 at 3:27 PM
    Ktaco
    Talking to other people it turns out these marking are more than likely just machined into the case from factory for clearance. When I looked closer at them I can definitely see uniform "etch" marks that appear to be from machining.
    Looks like I'm in the clear.
    travelfeet likes this.
