Weather-Proof Bed Storage Bins ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sargechris, Dec 3, 2012.
  1. Dec 3, 2012 at 3:41 PM
    Sargechris
    Sargechris [OP] Well-Known Member
    Oceanside, CA
    13 DCLB 4x4 TRD Sport/Tow Pyrite Mica
    BFG AT KO 265/70R17 Tires, SnugTop Sport Hi Liner, Yakima Racks / Load Warrior, WeatherTech Floor Liners, BedRug/BedMat
    I use my truck bed as my camper. I go off road some. The built-in bed sidewall storage bins fill with dust due to the drain holes and the latches.
    Anyone had success sealing these bins to keep the dust out (& the bin contents clean?)..
    :cheers:
  2. Dec 3, 2012 at 6:16 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
  3. Dec 3, 2012 at 7:02 PM
    Sargechris
    Oceanside, CA
    Some fantastic suggestions! Thanks! :thumbsup:
  4. Dec 3, 2012 at 7:25 PM
    12DblCab
    12DblCab I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    Carpeting in the side boxes might also reduce the noise while going over bumps. I have heard others say they wrapped their stuff in a towel before putting it in the storage boxes. I may have to experiment with carpeting.
  5. Dec 3, 2012 at 8:05 PM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    For precisely the same reason, I just got done weatherproofing those boxes. I used metal foil tape to cover all but the corner drain holes, shaping a bump around the hinges so that the door parts don't punch through and override the entire purpose of what I was doing. For the outer edges I used 1/4"x1/4" foam weatherstrip from Home Despot, ran around the outermost edges of the boxes; I did the same with my 120V electrical outlet. For the smaller cubbies above the wheels, I pulled them out and used the same 1/4"x1/4" foam tape.
    Things held up well for my over-350 miles of no pavement in Death and Saline Valleys over Thanksgiving week. I just wish the windows on my shell had a bit more resistance so that when I lock the latch open they don't slide open (I know, I asked for it, but I needed easy access through the side).
    I had considered using some spray-can rubber leak sealant (kinda like Plasti-Derp), but I had the parts on hand, and they were MUCH cheaper. And they worked just fine.
  6. Dec 5, 2012 at 5:42 PM
    Sargechris
    Oceanside, CA
    MACH 375: I followed your lead and did exactly as you suggested... I think it will work great. Thanks!! :thumbsup:
