Weather Tech Window Deflectors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eagledynasty, Dec 28, 2011.
  1. Dec 28, 2011 at 1:45 PM
    Eagledynasty
    Eagledynasty [OP] The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Just got weather tech window deflectors on my 2009 off road tacoma. The windows arent going up all the way and when I push them to the limit to get them up it squeks. I believe its rubbing on the back of the window deflectors. There isnt enough room for both of them to fit I guess. Im 99% sure I installed them correctly so are there any ideas to get the windows to roll up all the way flawlessly? Or anyone who has had the same problem as me?
  2. Dec 28, 2011 at 1:54 PM
    nvrenuf
    nvrenuf Whatever
    Bellevue, NE
    10 TRD Sport DCLB
    5100s Front & Rear, Icon 3-leaf add-a-leaf, OME 885s, LR UCAs, K&N CAI, Window Tint, Weather Tech Vent Shades, Weather Tech Floor Liners, De-badged, "Custom" clevece Hitch receiver, Avid Off-Road bolt-ons, Satoshi, Cab Mount Chop (Relentless Fab), Hood Hinge brackets/Duallys (Relentless Fab), Jumpers LEDs (Fogs, DTRL, Turns, Reverse, License Plate, Interior).
    Mine are doing the same thing. I thought it may have been because it was cold out when I installes them... I'll see if it still does it when it warms up a bit.
  3. Dec 28, 2011 at 2:03 PM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    Mine do this, it's just them squeezing together to fit. No worries
  4. Dec 28, 2011 at 2:10 PM
    Eagledynasty
    AJ
    Worcester, MassHole
    I thought it was just cause it was cold also and the rubber wasnt molding right to it.... will the window motors run out or burn out over time if it keeps rubbing up against the deflectors?
  5. Dec 28, 2011 at 2:30 PM
    johnanm
    Up
    The way I see it, it's less strain on the motor than if you held down the window up switch while the window was already up (ie not moving). The window motors are designed to cope with quite a bit of this behavior. It's a little annoying to know that they rub, but have confidence that you're not harming the motor.
    Interesting history: In the late 90's it was discovered that some people (particularly adolescent females) liked to play with the buttons while riding/driving and were contributing to early failure of the motors. Most manufacturers have since equipped more durable motors to prevent early failure.
  6. Dec 28, 2011 at 2:33 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've read other reports of the Weather Tech window visors having fitment issues. I'd get the widows up all the way and not roll them down for a month to try to get the plastic to conform (best to do during the summer.) Another option I'd try is to heat the plastic up and then raise the window...let cool down completly before checking the fitment.
