Weatherstripping for door
Discussion in '1st Gen. Tacomas (1995-2004)' started by Maestro, Dec 4, 2016.
  1. May 24, 2022 at 6:28 AM
    rhoderunner
    rhoderunner Well-Known Member
    Roy
    Mesa Arizona
    1999 Tacoma
    All, Well i've finnaly torn my drivers door seal. The cheepest Toyota seal is arount $150.00 Does anyone know of an aftermarket seal that is good enough for my truck? I know that the extra cab and double cab use the same seal.
    thanks
  2. May 24, 2022 at 6:36 AM
    everaustin
    everaustin Well-Known Member
    1st Gen 4WD SR5
    I was just thinking about this myself. Luckily mine is in good condition still, but there will come a time it'll need to be replaced.
  3. May 24, 2022 at 7:58 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just how bad is it torn ?
    Can you splice in a new piece ?
  4. May 24, 2022 at 4:01 PM
    rhoderunner
    Roy
    Mesa Arizona
    1999 Tacoma
    The seal is only torn on the area just in front of the drivers seat. Next time i hit a salvage yard I will cut off a section and see if i can splice it.
    Rhoderunner
    Bivouac likes this.
  5. May 24, 2022 at 10:19 PM
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    https://www.summitracing.com/parts/FCD-KT3013
    I have this kit from Fairchild. Matches OEM. The only difference is they put some kind of like foam inside areas of the weather stripping. The size for the opening is spot on and they trim it to match OEM, like the area for the door sill cover. The only thing I have found is that because of the foam that is placed inside the weather stripping, the door takes more effort to shut. I’m waiting to see if the foam is designed to break down and provide a better fitment to area that normally break down faster. I will be reaching out to the company to ask a few questions. As of right now, I am undecided, they fit great, just questions the foam that is inserted.
    Laxtoy likes this.
  6. May 25, 2022 at 4:08 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    I’d like to add that my oem weatherstripping had foam inside on the top rear corner, held in place by a rubber pin. Same thing along the windshield area. Looks like some soft, closed cell foam rope.
  7. May 25, 2022 at 6:10 PM
    lm546
    Craig
    Tucson, AZ
    Well, on that note, I guess they are same as OEM. Any chance I could get you to note on a picture exactly where your foam is? I checked mine out, and noted there is no plastic securing the foam in its location. I also noticed they are not in the exact locations you mentioned, but I am able to manipulate the foam. I’m sure the reason the doors are harder to close is because the foam is not in the proper locations.
    Rastopher[QUOTED] likes this.
  8. May 26, 2022 at 11:28 AM
    Rastopher
    Ras
    Sacramento, Ca
    Hi craig, I actually did take photos but it’s probably going to be a minute or two before I can make time to find them. I want to emphasize that they were held in place with one or two flexible black rubber (not plastic) pins per segment of foam. The rubber pins were like .75mm diameter rod with a flat head in one end and a cone on the other to retain it.
  9. May 26, 2022 at 8:09 PM
    lm546
    Craig
    Tucson, AZ
    Awesome, thank you. I messed with mine a bit and got the to a rough estimate of where I think they may go. I’m hoping that after I see your pictures, I them will stay in place when I get them set. Who knows, I could always try to run a needle and thread through it and it may work. Thank you for grabbing pictures!
  10. May 28, 2022 at 4:43 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I got these as well, same experience that it requires closing the door harder.
  11. May 28, 2022 at 8:43 PM
    lm546
    Craig
    Tucson, AZ
    Yeah, I honestly think it is because where the foam is currently sitting. I didn’t realize there was foam in the factory weather stripping or I would have made note of the location before I tossed them.
  12. May 29, 2022 at 5:34 PM
    Laxtoy
    Maltby, WA
    I was careful to put them back the same as oem, still have to slam the door with everything in the correct orientation.
    If you’re looking for correct oreirntaion-
    C17751FC-D1CD-4680-8C59-59AA024FB6A0.jpg There will be a short section of foam in the rear corner3779C67D-4A6C-4BAC-A1E0-E042FA6F3F58.jpg The long foam strip is for the a pillar of the door, starts at right about the end of the roof23C2ABEA-0EA2-49E4-93FA-5B53E390FD2E.jpg Ends a few inches below where the windshield stops
    beaverdamland and chrslefty like this.
  13. May 30, 2022 at 5:54 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Relating to the first picture, the drip weatherstrip on top (believe that is what you call it) comes loose my passenger side here and there. It's new OEM from Toyota. Is there a substance I can put on to keep it from pealing off? Thanks
  14. May 30, 2022 at 9:15 AM
    Laxtoy
    Maltby, WA
    I don’t think that was me referring to that piece, but I’d just use some silicone
    vettehigh likes this.
  15. May 30, 2022 at 11:29 AM
    #35
    lm546
    Craig
    Tucson, AZ
    Awesome! Thank you for the pictures. I have moved the small piece to the corner before. The foam pierce for the windshield is much further down, so I will move that up and report back. How long have you had yours in? Do you have any issues with shutting your doors?
  16. May 30, 2022 at 12:28 PM
    #36
    Laxtoy
    Maltby, WA
    Installed about a month ago, doors require being closed harder. When I initially installed I didn’t realize there were the thickened foam pieces and installed them incorrectly and it was very difficult to close them, knew pretty quick something was off
  17. May 30, 2022 at 10:49 PM
    #37
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Just changed driver with the real toyota one last weekend.
    It takes couple try's to shut now......hoping few weeks in hot sun change that.....
    I've developed a bad tic, now I try to slam passenger side too hard, at mid swing its....' o' shit'.......
  18. May 31, 2022 at 6:49 AM
    #38
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I did the DS side Toyota seal a while back also, and my door takes a bit more effort to close also. I just figured that was due to the new seal being so much better than the worn out old one.
  19. Mar 9, 2024 at 4:48 AM
    #39
    JingChuan
    JingChuan Active Member
    Resurrecting this thread to check on any results about door rattles. Thanks to the stiff Pro Comps and the absolute crap conditions of roads around south Indy, my doors rattle like crazy. I’ve checked all the mechanicals (I used to install auto glass so I’m pretty familiar with all that) and everything seems to be nice and solid. My next guess is the door seals are just flattened.
    Did anyone here notice that improvement after installing new seals?
  20. Mar 10, 2024 at 1:52 PM
    #40
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    Any idea of what type of sealant/caulk would be comparable to what comes inside of the OE weatherstrip? I have an area of the cab/door weatherstrip that allows water to migrate up under, and into the cab. I need to pull the weatherstrip and take care of some rust that has formed on the pinch weld in that area but would like to reapply whatever sealant that is afterward.
