Weatherstripping for door
Discussion in '1st Gen. Tacomas (1995-2004)' started by Maestro, Dec 4, 2016.
  1. Mar 10, 2024 at 2:47 PM
    #41
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Replacing the driver's side door seal made it take a bit more effort to close the door, so if anything is loose, it could make a difference.
  2. Mar 23, 2024 at 11:30 AM
    #42
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Anyone else have the same experience? The ones I got from rockauto will actually create a buzzing sound from the top of the door between the a pillar and b pillar from wind being let in above 60 mph, happens on both sides after being replaced and it’s been more than a year since replacing, driving me fricking nuts. If I push out while driving the noise stops, obviously not a tenable solution. I’m close to pulling the trigger on OEM, but dounds like others have similar experience with the door being harder to close, any noise??
  3. Mar 24, 2024 at 12:40 PM
    #43
    twtruck
    twtruck Active Member
    2001 Tacoma Double Cab
    JingChuan and Gen1andDone like this.
