weathertec mats in back of 5sp. access cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by monkey wrench, Apr 4, 2011.
  1. Apr 4, 2011 at 8:08 AM
    monkey wrench
    monkey wrench [OP] Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    hey,
    i ordered front and rear weathertec mats for my 2011 ac. i have the 5sp and it appears they do not fit without trimming into the back/access cab area. anyone successfully installed them into the back? i'm doing some stereo install stuff in a week or so and thought if i pulled out the rear center console in the process i could get a good clean line to trim the mat.
    has anyone else run into this issue. if its not going to work out i'll just send the rear mat back before i cut it up.
    thanks. i think this is my first post.
  2. Apr 4, 2011 at 9:34 AM
    monkey wrench
    sean
    somerset, ca
    stock 4x4
    i did a second search while spelling weathertech correctly and found some info. my bad.
