Weathertech floor liner emblems (TRD)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 1slowvq37, Jul 30, 2016.
  1. Nov 9, 2016 at 11:50 PM
    #141
    1slowvq37
    1slowvq37 [OP] Well-Known Member
    Jose
    Tecate BC MX / Chula Vista CA
    bone stock superwhite trd sport
    new car smell pine
    Sorry, I just been super busy working 12-15 hours per day. In the first chance, I'll go and pick up the samples and will post pictures.
    All orders were shipped today!! Thanks!
  2. Nov 13, 2016 at 6:02 PM
    #142
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Just noticed the other day mine are doing it too.
  3. Nov 22, 2016 at 1:51 PM
    #143
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Decided that I got tired of mine popping off after epoxy so I decided to drill holes and bolt them in. For any that are interested I went to Home Depot to the bolt section and bought some of the black bolts. These bolts come in packs of three and are the smallest metric sized bolts which are m3-0.5 x 6mm and a five pack of nylon lock washers that are m3-.05. These will require a size 2 Allen wrench for the bolt and some pliers or a small adjustable. I drilled two holes opposite from each other into the bolts wide enough for the threaded portion of the bolt with a 3/32 drill bit which you will have to slightly enlarge the hole from this size. The top part of the bolt has a wider head so I took my time with a 7/32 drill bit and slowly drilled a hole through just the clear plastic portion. Keep in mind these don't take much to drill through. Feel free to ask any questions. Hardware was less than two bucks to get with two packs of bolts and a pack of washers.
    Coot
    AR15xAR10 likes this.
  4. Nov 22, 2016 at 2:24 PM
    #144
    hackeradam
    hackeradam @the.trd.pro
    Adam
    HTX
    2017 Cement LT TRD Pro | 1965 FJ40 383 SBC
    If you go that route, I'd use some black nylon rivets. Just an idea.
    Tac0maSteve likes this.
  5. Nov 22, 2016 at 2:25 PM
    #145
    hackeradam
    Adam
    HTX
    Any update on the TRD Pro badges?
    1bad2k likes this.
  6. Nov 22, 2016 at 2:35 PM
    #146
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I see how that might look clean but I wanted something small that I could recess into the plastic and not have a long shaft underneath the mat. Honestly you dont really notice them sitting in the truck due to the shadows and height.
    Coot
  7. Nov 22, 2016 at 2:50 PM
    #147
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    What are the dimensions?
  8. Nov 22, 2016 at 3:17 PM
    #148
    hackeradam
    Adam
    HTX
    Cool. Yea, I bet some stainless pan head allens or torx would look good, too. You're definitely on to something :thumbsup:
    Coot83[QUOTED] likes this.
  9. Nov 22, 2016 at 3:19 PM
    #149
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I was thinking the same thing with a stainless version. Im sure depending on the user, either could work pretty well.
    Coot
  10. Nov 22, 2016 at 5:10 PM
    #150
    TegoTaco
    Ontario, Canada
  11. Nov 24, 2016 at 10:05 AM
    #151
    Corntaco
    Corntaco New Member
    Bob
    08 trdor
    Just ordered a OR set. thanks for providing these
    1slowvq37[OP] likes this.
  12. Nov 30, 2016 at 10:19 PM
    #152
    1slowvq37
    Jose
    new car smell pine
    Sorry for the late post.... had a busy week with the family and work.... hope everyone had great thanksgiving. All order were shipped this morning.... only a few sets left. As for the pro and tx emblems..... I will swing by the shop and see if they got my samples. Thanks!
  13. Nov 30, 2016 at 10:19 PM
    #153
    1slowvq37
    Jose
    new car smell pine
    Pm me your info... Ill send you an other set.
    SpruceTaco[QUOTED] likes this.
  14. Dec 7, 2016 at 8:27 PM
    #154
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I got a set of OffRoads and one side has done the same. Turned almost reddish.
  15. Dec 14, 2016 at 5:42 PM
    #155
    Scribbles
    Scribbles Well-Known Member
    LoUiSiAna
    2010 SR5 PreRunner
    None yet
    I didn't read thru the whole thread, but what is the best way to glue them down?
  16. Dec 14, 2016 at 6:05 PM
    #156
    jhinderliter
    jhinderliter Well-Known Member
    West central il
    2009 Double Cab TRD Off Road
    Payment sent on a set OR
  17. Dec 25, 2016 at 5:03 PM
    #157
    Ulysiss
    Ulysiss Well-Known Member
    Ulysiss
    La Puente, SGV
    2013 Long Bed, PreRunner, TRD Sport
  18. Jan 12, 2017 at 11:55 PM
    #158
    TacoIronMan
    TacoIronMan Member
    Skyler
    97055
    2006 tacoma TRD offroad 4x4
    just sent a payment on PayPal for the Offroad set
  19. May 30, 2017 at 6:08 PM
    #159
    GuamTaco4x4
    GuamTaco4x4 Well-Known Member
    Allen
    Chapel Hill, NC
    2015 Inferno Tacoma TRD Pro
    TRD Supercharger AMP Power Steps Retrax bed cover Ceramic tint Custom Shift knob Weather Tech mats
    Any update on the TRD Pro badges? Thanks
    1bad2k likes this.
  20. Nov 12, 2017 at 12:21 PM
    #160
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    OP are these still available?
