Weathertech for 2012 Access Cab Poor Fitment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PDXTacoma, Apr 3, 2012.
  1. Apr 3, 2012 at 6:57 AM
    PDXTacoma
    PDXTacoma [OP] Active Member
    Portland
    2012 Tacoma
    Received my weathertech floor liners for 2012 access cab. The front mats fit perfect, but the rear liner was having some fitment issues over the middle section. It looks like it is pulling both the side parts toward the center.
    So, would you consider the access cab to have second row storage (it looks like a center cup holder in the back)?
    I have weathertech model number 440214 in the back (with second row storage). Has anyone tried model number 440212 in the back (without second row storage).
    Thanks for the help
  2. Apr 3, 2012 at 8:07 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I have the 440214 in the back of my 2009 AC. As far as I understand there were no changes made to the back of the AC in 2012.
    When I installed mine they were a VERY tight fit but with a little bit of coercing they fit in and they have stayed in place very well. You might want to post a picture to help display the problem you are experiencing. There could be a problem with the rear mat but I haven't heard of that happening in terms of defective measurements.
    The 440212 will not fit the AC with storage as the part that goes over the hump is wider and will not fit
  3. Apr 3, 2012 at 9:01 AM
    PDXTacoma
    Portland
    2012 Tacoma
    Pulled off internet of non 2012 access cab with good fitment. I believe that it is a 2009 or 2010
    Here is what I think a storage box looks like
    This is the center storage (if thats what you want to call it) the 2012 access cab has. It is different.
  4. Apr 3, 2012 at 12:42 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    I have spoken with Weathertech on this, as this will be the second time I have heard the issue on the 2012. As of this moment, Weathertech says that they test fitted the truck and the number 4x0214 is correct. They will follow up with their R&D team though to be sure.
  5. Apr 3, 2012 at 1:31 PM
    PDXTacoma
    Portland
    2012 Tacoma
    Sorry for the crappy picture, but this is the poor fitment
  6. Apr 3, 2012 at 1:39 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    if that's the correct mat you could try relaxing that area with a heat gun.
  7. Apr 3, 2012 at 1:43 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Funny how pictures get around. That's my truck and it's 2011. I got these a month after Weathertech made the change by adding the rear center storage an option.
    To the OP. other than removing the lid to the center box, you can see that the '11 is sloped up from the floor, where it looks like the '12 is at a full 90°. I suggest you call Weathertech on this, as they may not know.You could get your money back for the mat, and if you're the first to report the bad fit issue, maybe a free mat when they get their shit sorted out.
    Frank
  8. Apr 3, 2012 at 2:00 PM
    PDXTacoma
    Portland
    2012 Tacoma
    Sorry, I pulled your picture, then forgot which of the millions of weathertech posts it came from. I am going to contact weathertech tonight about the issue.
  9. Apr 3, 2012 at 2:16 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Hey OP...
    I have a 2010 access cab with rear center storage box. Don't know what might have changed in 2011 or 12 .. but in 2010, the rear Weathertech wouldn't fit in the access cab without moditication. Fortunately it's very easy to do!
    You have to remove the rear center storage box .. It's just 3 bolts! Then pull the box. Lay the Weathertech down in the rear. Then put the center storage box back in place. Mark the 3 screw holes on the mat with a Sharpie.
    Then take the rear mat, and drill out those 3 holes. A drillbit bites right through. Now reinstall the mat in the rear, set the rear storage box back in place, make sure the box holes are lined up with the newly drilled mat holes, and reinstall the 3 bolts.
    The mat now fits perfectly! True it's locked down .. but they're small mats. Just vacuum off, then spray down with some Simple Green (or other mild cleaner) and wipe.
  10. Apr 3, 2012 at 7:29 PM
    PDXTacoma
    Portland
    2012 Tacoma
    Talked to weathertech. They acknowledged that they made a mistake with the 2012 access cabs. Supposedly mid 2012 the factory changed something and the complaints started coming in about a week ago. They are paying for shipping and giving a refund. They also are going to let me know when the fixed ones come in. Sounds like an honest mistake. Good service!
  11. Apr 3, 2012 at 7:38 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I haven't gotten mats yet for my 2010 Double Cab and what from what you guys are posting shows me great service. They are willing to pay for the shipping and send it back and give you a refund. That's just awesome! Now when you get a refund and the issues get fixed you get the right ones that fit.
    Props to Weather Tech.
  12. Apr 9, 2012 at 9:56 AM
    cast71
    cast71 Active Member
    Pete
    NY
    2012 AC SR5 4X4 I4
    yellow wire mod, mud flap mod, differential breather mod, steering shaft tsb, rear leaf spring tsb
    Can you guys post an update, when weather tech notifies you of the updated mats? Thanks;0)
  13. Apr 14, 2012 at 12:35 PM
    parksnrecmatt
    parksnrecmatt Member
    matt
    co/nc
    2012 sr5 v6 6spd 4x4
    gt covers weathertech
    ordered my weather techs about a month ago and just got my rear over the hump. it did not fit my 2012 with the rear console. just got word today expect 12 weeks before new ones come out, so really more like 18 weeks till i see one that fits. i had the option to return for free and a refund of keep the wrong one and wait for the new one. so the waiting game starts again.
  14. Apr 14, 2012 at 2:42 PM
    808Bradah
    808Bradah Well-Known Member
    Hawaii
    2012 Super White SR5 4cyl
    emailed customer service and took pictures of the poor fitment, gave the part number as they told me too and I haven't got a response back from them yet, its been 5 days.
  15. Apr 15, 2012 at 2:41 AM
    808Bradah
    Hawaii
    what to do?
  16. Apr 15, 2012 at 5:00 PM
    NEAScott
    Scott
    Toledo, Oh
    Join the party and wait along with everyone else. Someone will be around shortly to pass out hors d' oeuvres.
  17. May 15, 2012 at 10:36 AM
    NEAScott
    Scott
    Toledo, Oh
    Just checked in with Weathertech on this. Still being told about 6 weeks out.
  18. May 15, 2012 at 12:27 PM
    jassco
    jassco Well-Known Member
    Boston
    2008 4runner, UrbanRunner Silver
    I removed my rear console and did it on a friend's '12 too. The '12 is more of a 90 deg angle and so is the middle console, so that person was correct. I had to cut both my front (clutch pedal) and rear mats to get them to fit correctly in my '10. I was fine with it, but understand people not wanting to.
    They say it fits then it should, but they messed up. If people can wait for correct ones then there is no issue here. If not grab a dremel and fix it in 2 minutes. Boy that console addition is useless and creates more issues storing things in the AC then it solved.
  19. May 24, 2012 at 8:06 PM
    parksnrecmatt
    matt
    co/nc
    Just got the a call from WeatherTech. The redesigned rear liner will be in the mail to me by next week. Sounds like they fixed the problem.
  20. Jun 28, 2012 at 12:59 PM
    cast71
    Pete
    NY
    2012 AC SR5 4X4 I4
    Just got the rear weathertech's for a 2012 access cab with center console. They fit perfect and got here a few days earlier too. Thanks Scott.
