weathertech in a manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crew Dawg, Mar 4, 2011.
  1. Mar 6, 2011 at 9:25 PM
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    i need to do this
  2. Mar 6, 2011 at 9:35 PM
    Speed Nut
    Speed Nut Well-Known Member
    I went with Husky liners. No need to trim. Perfect fit right out of the box. And they were less expensive.
  3. Mar 6, 2011 at 9:39 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Spoke with a vendor on a 2008 VW GTI, they had said the same thing. The vendor called WeatherTech, and the only reason they were saying no fit was because of the clutch pedal. Minor trimming, you're good to go.
    That's nice. Thanks for sharing. :cool:
  4. Mar 6, 2011 at 9:42 PM
    MQQSE
    MQQSE Bannable Galloot
    Rob III
    Palmer, Alaska
    "Stitch" Still Stock Concept Truck
    Shtuff
    Trimmed mine (07 w/ WeatherTechs bought in 2010) almost identical to Ipunchwalls. Note: When the temps got into negative numbers I ended up trimming a little bit more. The mats got stiffer in the colder temps and didn't lay as flat. Went right back into place once the interior heated up, but something to consider.
  5. Mar 7, 2011 at 6:20 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I bought the $99 front and back set...no trimming required front or back.
    no clutch interference. I like them a lot.
    Good luck.
    Paul
