WeatherTech Mat Fit Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Jun 21, 2012.
  1. Jun 21, 2012 at 9:48 AM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've noticed more than a few threads concerning these mats...sometimes they don't fit exactly as advertised. Here's a couple easy things you can do to fix them...
    If the seat rails hit the rear mats when the seat is adjusted back use a razor blade or a dremel to carve the plastic to alleviate the rideing condition.
    If the front mats aren't fitting snug use a heat gun to mold the plastic to the desired shape and have a way (weights/clamps/ect) to hold the new shape until the plastic cools down completly. I would advise doing this with the mats out of the truck.
    If the WeatherTech logo becomes separated from the mat use double back tape to secure it...I tried silicone adhesive but it wouldn't bond to the plastic.
