weathertech mats in a manual truck, pics?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Nov 26, 2010.
  1. Nov 26, 2010 at 10:24 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    those of you who had to notch your mat, what does the notch look like? i'm debating here what the heck to get and i like the weathertech digital fit units BUT i have a 6 speed manual.
  2. Nov 26, 2010 at 10:38 PM
    USFCON
    USFCON Well-Known Member
    Jeff
    Melbourne, Florida
    Prerunner SR5 Off Road
    FLM URD Short Shifter Debadged Gate 4 D-ring add on Weathertech floor mats Sport Wheel Swap Color matched Grill Bed lights Air freshner mod AAL Bilstein x 4 Tacolean Spacer Tins Bike Fork Mount Sexy Tires Blacked out Valence
    I took a dremel to it, doesn't look bad. You don't reallly need to notch it just take a little off at a time. Pics when i get off work.
  3. Nov 26, 2010 at 10:41 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    i took an exacto knife... put the weathertech in. Push the clutch in and use a marker to mark where the clutch touch the mat. THen just cut out that area and poof it works beautifully.. I really is much easier than you might think. I was concerned before i did it as well. It is VERY simple.
  4. Nov 26, 2010 at 11:12 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    thanks guys.
  5. Nov 27, 2010 at 1:21 AM
    Cuda444
    Cuda444 Well-Known Member
    New England
    TRD Off-Road
    Access Limited Bed Cover, URD Short Shift Kit, 25% Tint all around, WeatherTechs, Kenwood DNX-6160, 2 - IDQ10 sub, Hybrid Audio Clarus 6.5's, JL 500/1, JL 300/2, Mr.Marv Enclosure/Amp Rack, Morimoto Stage III Retro Headlights, Blazer Fog Retro
    I used scissors to cut just below where the clutch hits and cleaned up the sharp edge with some fine grit sandpaper. It looks like it came from the factory. REALLY easy to do... nothing to worry about.
    PS - These mats are awesome and totally worth it.
  6. Nov 27, 2010 at 1:50 AM
    atavuss
    atavuss Well-Known Member
    why does the mat have to be notched/cut? does the mat keep the clutch from being depressed enough for proper function?
    I have the Toyota all weather mats in my 2 door 4x4 with a manual transmission and I don't notice any shifting problems.
  7. Nov 27, 2010 at 4:50 AM
    Toyo_Jet
    Toyo_Jet Well-Known Member
    Shane
    Flatlands of Indiana
    10 4X4 V6 SR5 access Cab
    I put weathertechs in mine and did not notice any interference or catching. Was prepared to trim, but didn't have to.
  8. Nov 27, 2010 at 6:47 AM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    x2 on my 2010
  9. Nov 27, 2010 at 10:31 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Here's a pic of how much you need to trim so you don't catch your clutch pedal... Just mark it with the pedal pressed down then take scissors and trim, very easy...
  10. Nov 27, 2010 at 10:36 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    x2
  11. Nov 27, 2010 at 11:09 AM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    x3
  12. Nov 28, 2010 at 11:48 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
  13. Nov 28, 2010 at 11:51 AM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Was just about to link my thread.. and there it is. :p
  14. Nov 28, 2010 at 11:55 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    haha, nice work ; )
    thanks.
  15. Dec 7, 2010 at 12:36 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    I used a razor blade to trim mine. Heres how it looks. Doesnt catch at all :)
  16. Dec 7, 2010 at 12:52 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    worth it, do it and buy it...its that easy, straight blade and it was over....if thats what got ya on the fence, then you should just get 'em
  17. Dec 7, 2010 at 1:41 PM
    eutrash
    eutrash Member
