Weathertech Mud Flaps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mx355, Nov 16, 2014.
  1. Nov 16, 2014 at 2:05 PM
    mx355
    mx355 [OP] Well-Known Member
    Trent
    TX
    2020 Trd Pro
    Kings, Method 316, Nitto Ridge Grappler
    Does anyone have any pictures of the Weathertech Mud Flaps installed? I have see a few low lighting bad pictures of them, but would like to see how they look from a side view in good lighting as well as angled views. If anyone has any pictures please post. Thanks in Advance. Husky Flaps are welcome as well.
  2. Nov 17, 2014 at 4:21 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I was just about to start a thread asking about length of weathertech vs length of husky front flaps. Would like to see pictures side by side as well as how each of the follow the contour of the body
  3. Nov 17, 2014 at 5:06 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And will they rub on my 285's? Took my stock ones off for that reason.
  4. Nov 18, 2014 at 4:22 AM
    mx355
    Trent
    TX
    2020 Trd Pro
    Exactly what I'm wondering, Hoping someone with weathertechs will chime in with pictures since their product is a different looking style than OEM/Husky Factory look.
  5. Nov 18, 2014 at 4:40 AM
    Dave
    Dave Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    The Husky's are over $20 more for the set, are they even as good as the WeatherTechs ?
  6. Nov 18, 2014 at 5:37 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if stock rubbed, these will rub
  7. Nov 18, 2014 at 6:55 AM
    ejl923
    Eric
    Western Mass
    I forgot what thread i was reading, but at least one guy said he preferred the fit of the husky's better and he's had both.
  8. Nov 21, 2014 at 9:21 PM
    mx355
    Trent
    TX
    2020 Trd Pro
    Still requesting pictures of either if anyone has them. thanks
  9. Nov 23, 2014 at 2:34 PM
    Dave
    RI/Vt
    08 4x4 Xtra Cab
    Because of the way they are shaped, it's basically impossible to make your own that would look decent.
