Weathertech Mud Flaps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by davistld01, Dec 12, 2022.
  1. Dec 12, 2022 at 3:49 PM
    davistld01
    davistld01 [OP] Well-Known Member
    Terry
    2019 White Tacoma SR5
    Do any here have experience with the Weathertech mud flaps? If so, how do they compare to the OEM parts?
  2. Dec 12, 2022 at 4:19 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    They fit fine. Easy install. I am unable to compare with OEM though.
  3. Dec 12, 2022 at 4:20 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I have them at the front for few years. They are slimmer compare to "boxy" oem. Otherwise look identical
  4. Dec 12, 2022 at 5:41 PM
    davistld01
    Terry
    Are they more or less flexible than OEM?
  5. Dec 12, 2022 at 5:56 PM
    Vlady
    Issy, WA
    I would say the same. Pretty ridged. OEM designed as "[" (hence "boxy") vs WT "I'.
    WT is wider by roughly 1.5".
    They will be ripped off of the mounts if you drag them over an obstacle.
  6. Dec 13, 2022 at 3:12 AM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    They look great, but collect grit underneath. So it is best to remove them for cleaning the flares or fenders periodically. They will rub if you go up one tire size. Had them for the first two years and then swapped them out for Rok Blokz which are way more flexible, before running without all together.
  7. Dec 13, 2022 at 3:37 AM
    davistld01
    Terry
    Thanks for that. I’ve gone one size wider with my Cooper AT3’s and would rather not have flaps at all than to have the tires rub. I’ll probably never do any real off roading, and my only concern was snow/ice during the coming winter months.
  8. Dec 13, 2022 at 5:04 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    In my experience with them, they are slightly wider, but not as long as the OEM flaps. I’ve had both on second and third gen Tacomas. I prefer the Weathertech flaps.
    The more flexible mud flap makers are preferred by many here. RokBlokz and Rekgen come to mind.
  9. Dec 13, 2022 at 6:36 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    I've had OEM, Weathertech, and now cheap knockoffs from Amazon with no issues from any off them, however I do not off-road. No complaints!
  10. Dec 22, 2022 at 11:06 AM
    davistld01
    Terry
    Anybody use Husky flaps? Just got delivered a set from Amazon. Not installed yet because they were a day late…and Missouri is covered in snow today! But if they’re junk I can send them back.
  11. Dec 22, 2022 at 2:26 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Cannot say enough good things about my TuffSkinz. They are a softer material so will have some forgiveness to them. They are also adjustable which is nice to add some extra protection against rocks.
