Weathertech Mudflaps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JEEPNIK, May 13, 2020.
  1. May 13, 2020 at 12:33 PM
    JEEPNIK
    JEEPNIK [OP] Well-Known Member
    2020 Voodoo Blue TRD Sport
    I have a 2020 TRD Sport. And wanted to install mud flaps. In the past I've used Weathertech parts to my satisfaction. However, I just ran into an issue.
    I installed the front mudflaps with no issues. Although their "no drill" is a bit untrue. You do need to drill a hole in the wheel well liner. No big deal.
    The problem arose with the rear flaps. The holes in the flap do not line up to those on the truck. In fact they are way off. A quick call to weathertech and I found that even though the flaps are listed as fitting my vehicle they sent the wrong ones. They are sending new flaps so we'll see how they match up.
    But just as a warning, if you order their rear mudflaps for 2020's check the hole pattern before you get frustrated. The part number sent was 120055. We'll see what they send as a replacement.
  2. May 13, 2020 at 12:50 PM
    P-Dawg
    P-Dawg Factory 2 Seater
    Pete
    Chicago
    2020 SR AC MGM Utility Pckg.
    My Weather Tech fit perfectly. You just have the wrong ones.
    Vlady likes this.
  3. May 13, 2020 at 1:16 PM
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    Just put them on my 2020 Tacoma this week- they fit perfectly.
  4. May 13, 2020 at 3:47 PM
    JEEPNIK
    There's a notation in red on the box that has what looks like an expiration date. Anyway it says exp 3/19. Cold be old stock that someone from weathertech grabbed. The fellow I spoke to said they had sent the wrong ones when I gave him the part number. Go figure.
  5. May 13, 2020 at 6:53 PM
    muskratX22
    Dave
    Illinois
    My 2020 does not have wheel moldings, there is a difference in the mudflaps.
    What I liked is Weathertech uses the Toyota hardware and existing holes.
  6. May 21, 2020 at 11:44 AM
    JEEPNIK
    Okay just for an update. Weathertech sent another set of rear mudflaps. They didn't fit either. So, I checked and they both have the same hole pattern. The first box was labeled 120055, the second 120056. Then I looked even closer and found that the first set in the 120055 box were actually 120056 flaps. I'm sending the entire mess back to weathertech.
    For all their advertising about laser measuring for exact fit and so on, they can't even get the product in the right box.
    Now it is possible that the 120055's would fit properly, but I've spent several hours on a 30 minute project. Too bad I can't invoice them for minimum four hours like I do my customers. A couple of grand might make them wake up.
    My advice, stay away from weathertech.
  7. May 21, 2020 at 11:48 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Wow take the company down over what sounds like good customer service, over a miss boxed item.
  8. May 21, 2020 at 11:49 AM
    JEEPNIK
    Yep, it's mistakes like this that cost customers time and frustration, and the company customers.
  9. May 21, 2020 at 3:39 PM
    muskratX22
    Dave
    Illinois
    The mudflaps I purchased from Weathertech were the set 110056 and 120056.
    These are for Tacomas without fender flares. Fit great.
