Weathertech Question
Discussion in 'New Members' started by motttocs, Jul 29, 2012.
  1. Jul 29, 2012 at 4:10 PM
    motttocs
    motttocs [OP] Active Member
    South Jersey
    Tacoma SR5 4WD
    Just installed a set of in-channel Weathertech deflectors on my 2012 Tacoma. No matter what I do the window hits the edge (rear) and the window rubs the last inch or so on the way up front windows only. Rear windows are fine. I left the window closed for twenty four hours and still rubbing. I have installed and re-installed numerous times and end up with the same result. Is this normal?
  2. Jul 31, 2012 at 11:08 AM
    motttocs
    South Jersey
    Tacoma SR5 4WD
    Sorry I thought I posted in the appropriate forum. Anyway, problem fixed
  3. Sep 6, 2013 at 6:02 PM
    Hotrodroxie
    Hotrodroxie Member
    NEO
    08 Tacoma dbl 4x4, poor girl stock
    How did you fix it? Do you have a pic of what your talking about?
  4. Sep 7, 2013 at 4:54 AM
    motttocs
    South Jersey
    Tacoma SR5 4WD
    Make sure you put the front lower section in first a seat it in good. Work up and around til you have to bend the deflector. and finish seating. I'm not sure what it said to do with the window placement (partially down) but that is the Key. Good Luck
