Wedge campers and off roading
Discussion in 'Outdoors' started by phdog, May 8, 2025.
  1. May 8, 2025 at 10:13 AM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I was wondering if anyone can chime in on if the addition of a wedge camper (GFC, Super Pacific, etc.) creates any issues off roading. I know they don't weigh that much, but the extra weight higher up will raise the center of gravity and the overhand over the cab seems like it could catch tree branches.
    I'm not a serious off roader (whatever that means) but I frequently explore roads that end up being rather narrow, overhung with trees, rocky, etc.
    Thanks.
    N64_Wallmaster likes this.
  2. May 10, 2025 at 8:18 PM
    370HSSSV
    370HSSSV Member
    I have not had any problems, I don't have sway bars, expect a bit more body roll, no branches give me problems on tighter trails.Do expect some pin stripes on the camper tho.
    Flex-AZ likes this.
  3. May 12, 2025 at 8:07 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. That's good to hear. Hopefully a few more chime in for more consensus.
  4. May 12, 2025 at 8:41 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Do you commonly find yourself driving somewhere with only 6” of clearance above your roof before you hit rocks or large branches? If the answer is no, then you’ll be fine.
  5. May 12, 2025 at 8:47 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Based on my experience wheeling with people who have campers, the real questions are "how often am I driving through off-camber sections of trail, how do I drive through them now, and how will I be with the better part of a 250 to 450-pound camper (depending on model) being up above my head and way up above my center of gravity?"
  6. May 12, 2025 at 8:56 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I don’t know. I noticed next to no difference in off-camber stability with my GFC. It was on the lighter end to be fair.
    fatfurious2 and essjay[QUOTED] like this.
  7. May 12, 2025 at 9:08 PM
    essjay
    Concord, CA
    I'm considering several campers to replace my 250lb cab-height RTT/tonneau setup, and even though it may be less feature and convenience-rich compared to others (the Lone Peak, in particular), the significantly lighter weight of the GFC (over 100lbs less in most cases) has it at the front of the list for me. I've spotted enough guys with 400+ lb campers and similar (or even better) suspension setups through off-camber sections that I didn't even really consider obstacles with a lower COG and/or have told me that they kind that it's a cause for concern for me.
    edit: Not to say that I won't go the 400lb-ish route, because the Super Pacific and Lone Peak really do offer a lot of practical advantages over the GFC.
  8. May 12, 2025 at 9:10 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I still rally with my setup (super pacific) only tho so far has been mounts listening that shone the camper so you have some more things to worry about but didn’t notice much in terms of how it handles on trails.
    essjay likes this.
  9. May 13, 2025 at 9:52 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Kind of. I guess it doesn't happen that often, but sometimes there are trees close in on the sides so branches are extending over the trail and I'm envisioning them getting pulled into the gap. Small branches probably only get leaves stripped or branches torn off, but if a larger one snagged it might create some issues. I might get a roof rack to help act as a deflector for that.
  10. May 13, 2025 at 10:15 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Most of my off camber driving is just uneven ruts or sloped trails as I don't really do Moab-type stuff. Most aren't too bad, but a few times it's been enough to cause a little ass pucker and start wondering where the tipping point is. How much the camper affects this is the big question.
  11. May 13, 2025 at 10:18 AM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    To answer your question, yes, you will feel it in those pucker moments.
    That feeling goes up the heavier the top section of the camper is. Campers like a GFC, Topo Mesa, Super Pacific, etc. aren’t much weight, so you will be fine there. I wheeled all of Moab with a Vagabond strapped to the back of my truck and multiple people have done the Rubicon with one on their truck.
    The biggest improvement you can do is have proper suspension and more articulation. This makes the pucker factor come in at a much higher angle.
    All that being said, I drive my truck like a bat out of hell sometimes with a 450# camper bolted down to it and am 100% confident I will be fine.
    jerrybear likes this.
  12. May 13, 2025 at 10:19 AM
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    Ive hit up all the ohv spots in California with my taco and gfc, haven’t had any trail give me any more cause for concern than if i didnt. Only time i worried was with overhanging branches, which would be the same if it were to contact the roof of the truck
  13. May 13, 2025 at 10:42 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Ive got a wedge style RTT mounted on a cab height rack. Probably 3-4 inch gap between the top of the cab and the bottom of the RTT. Just enough for the shark fin. I tend to avoid trails that are super overgrown and low hanging, but still happens from time to time. Id say this isnt a big concern.
    A set of nice big spot mirrors can help a lot keeping an eye on the leading edge of the wedge from the drivers seat. (spot mirrors are great in general for wheeling IMO)
    The bigger concern for me has always been the higher CoG. But how much of an issue is that.. who knows :notsure:
  14. May 13, 2025 at 10:48 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. Where are you mounting the mirrors to watch the top of the cab area/wedge overhang?
  15. May 13, 2025 at 11:07 AM
    essjay
    Concord, CA
    If you're not doing anything all that offcamber very often, I'm sure it's perfectly fine.
    I feel like most of the issues are really more "what if I flip here because I didn't do the pro walk and self-spot or get spotted" than "I'm going to flip here because I didn't do that." I do think a lot of it really does simply boil down to the driver's knowledge and their comfort level with their setup.
  16. May 13, 2025 at 11:18 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I don't mount mirrors to watch the overhang on my GFC
  17. May 13, 2025 at 11:18 AM
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    How much do those GFCs weigh?
  18. May 13, 2025 at 11:19 AM
    fatfurious2
    David
    Ashburn, VA
    I think mine is about 275lbs
  19. May 13, 2025 at 11:20 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
  20. May 13, 2025 at 11:27 AM
    N64_Wallmaster
    Raleigh, NC
    2017 LTD 4WD
    That's insanely light for the space you get
    fatfurious2[QUOTED] likes this.
