Wedge Campers & Assorted Oddities
Discussion in 'Off-Roading & Trails' started by T4RFTMFW, Mar 14, 2018.
  1. Apr 15, 2018 at 4:15 PM
    #281
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I really don’t want to get in a pissing contest, but aluminum is NOT always stronger than steel. The material is always STIFFER than steel; the modulus of elasticity or Young’s Modulus of steel is 3x that of aluminum, so for the same part geometry (thickness, etc) aluminum will deflect 3x more than steel with the same load. But the STRENGTH of aluminum can be much higher, depending on alloy, than a low carbon mild steel. Finally, we are talking about DESIGNS and PARTS here, not just materials. An appropriately engineered aluminum part, like an engine piston, airframe, bike frame, boat hull, can be much stronger than a steel part. Or not ... it’s ultimately a factor of the design and manufacturing process, not just the material. I think the GFC camper is an elegant and creative product, but that doesn’t mean it’s the only solution.
  2. Apr 15, 2018 at 5:28 PM
    #282
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    Is there some sort of pull on the inside to close the camper or do you always have to be outside and use the fabric to lower the top? The fabric looks a little “light” in the video by the way it wrinkles in your hands.
    LTDSC and 916TacoTruck like this.
  3. Apr 15, 2018 at 5:49 PM
    #283
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Ummm. I close mine from the inside using the handle because there’s space to stand and pull it down with the bed in place. No grabbing and pulling of fabric on my drifter :notsure:
    LTDSC, 916TacoTruck and Bentrodder like this.
  4. Apr 15, 2018 at 5:53 PM
    #284
    Bentrodder
    Peter
    Cotati, CA.
    One reason I could see where I would want to be inside to close is if the weather turned to shit and I want to pack up and leave. I realize it takes less than a minute to close, but that’s one less minute I would be outside getting rained on while wrestling soaking wet fabric.
  5. Apr 15, 2018 at 6:30 PM
    #285
    tacomgee
    Blake
    NorCal - Ukiah
    My comment has nothing to do with being exposed to the elements. I just don’t understand the pulling of the fabric to close it is all. Seems like that could cause some issues down the road potentially.
    Either way, looking forward to checking yours out when we go camping :thumbsup:
    Ill show you mine if you show me yours :p
  6. Apr 15, 2018 at 6:41 PM
    #286
    frusteri4
    frusteri4 Well-Known Member
    Reno
    off road ACLB
    Pelfrey Front, CVT tiny, OME heavy,
    Somebody should make a cardboard one
    T4RFTMFW[OP] and LTDSC like this.
  7. Apr 15, 2018 at 6:52 PM
    #287
    I_eat_tacos
    I_eat_tacos Well-Known Member
    One thing I’ll probably want to add is a long elastic that connect at the hinges. How the alucab tent does. You place it on the fabric and the elastic tucks it in for you. Easy done. Should work on either design.
    kalieaire likes this.
  8. Apr 15, 2018 at 7:58 PM
    #288
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Cause both fly, one by design, the other temporarily for shits & giggles.
  9. Apr 15, 2018 at 8:26 PM
    #289
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm sure you do. But not a full 6' of space from the entire bed.
  10. Apr 15, 2018 at 9:33 PM
    #290
    tacomgee
    Blake
    NorCal - Ukiah
    What?
  11. Apr 15, 2018 at 9:35 PM
    #291
    Blackdawg
    Monte
    Wyoming/St. Louis
    With a wildernest open, the entire bed is open for you to walk around in. Full 6'.
  12. Apr 15, 2018 at 9:40 PM
    #292
    tacomgee
    Blake
    NorCal - Ukiah
    Oh. Gotcha. Yeah those were definitely a sweet setup! Tons of space
  13. Apr 15, 2018 at 9:42 PM
    #293
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah. Thats the advantage of the total flip out bed that the Wildernest/flippac/habitat have. Plenty of compromises to go with it as well though.
    was cool though. No joke felt like a small bedroom.
  14. Apr 15, 2018 at 9:55 PM
    #294
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Clearly you haven't used your tailgate in a while.
  15. Apr 15, 2018 at 11:03 PM
    #295
    danneskjold
    danneskjold Well-Known Member
    Brian
    Shoreline, WA
    2018 F150
    Anecdotally I've been using an Alu Cab aluminum shell with a 200 lbs tent on top for the last several months and it's held up great for close to 20,000 miles including me t-boning someone running a stop sign at 40mph.
    Obviously most of that is highway but a good amount of that is off-road as well. It's welded together and I haven't noticed any signs of the welds breaking. I'm not jumping my shit, but I certainly don't baby it either.
  16. Apr 16, 2018 at 4:30 PM
    #296
    dman100
    2016 TRD OR DCSB
    Do you have bed stiffeners? If so, what brand? Thanks.
    Anderson and Overlanerd like this.
  17. Apr 16, 2018 at 4:31 PM
    #297
    danneskjold
    Brian
    Shoreline, WA
    2018 F150
    Nope...I'm raw dogging it ;)
    Overlanerd likes this.
  18. Apr 16, 2018 at 4:38 PM
    #298
    Overlanerd
    Overlanerd Vagabond Outdoors
    Phil
    Benicia
    09 DCSB 4x4 OR 6spd
    315/75 R16 Falken MT's, SCS Ray 10's, Vagabond Drifter pop-up camper, BAMF sliders, Relentless skids, BAMF bumper, winch, Pelfreybilt rear bumper, Custom Alcan rear springs, King 2.5 coilovers w/ 700# springs, BAMF relocate kit with 12" Kings, Total Chaos UCA's, dual AGM batteries, kitchen sink & toilet (sold separately)
    Hit up @Bentrodder !
    Anderson, Porter707 and Bentrodder like this.
  19. Apr 16, 2018 at 4:46 PM
    #299
    Porter707
    Porter707 Well-Known Member
    James
    Ohio
    2020 F-250 Powerstroke
    Word on the street is @Bentrodder might have a 3rd gen solution soon too... :spy:
    Overlanerd[QUOTED] and Anderson like this.
  20. Apr 16, 2018 at 8:57 PM
    #300
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Agreed
    Just thought I would pop in to show some habitat love.. Alot of constructive discussion in here!
    AT is missing out by not participating in here imo. Im in no way affiliated aside from the fact I bought a habitat and am loving it, just got back from 8 day trip, didn't want to come home.
    Also has been great to be able to move my on board water / fuel tanks to the exterior walls.
