weight a tacoma sport can tow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ted Morrow, Aug 10, 2020.
  1. Aug 10, 2020 at 2:10 PM
    Ted Morrow
    Ted Morrow [OP] New Member
    ted
    2015 Tacoma sport v6 4 wheel drive
    I have a v6 2015 tacoma sport. I am planning to buy a travel trailer and trying to determine max weight my truck can comfortably tow. Any feedback is greatly appreciated
  2. Aug 10, 2020 at 2:18 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
  3. Aug 10, 2020 at 2:30 PM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    I have a 2015 TRD and tow a 3100 lb 21 ft trailer and find I wouldn’t want to tow anything heavier. Once you take into consideration two 30 lb propane tanks battery plus all your gear and yourselves the weight starts to creep up there. Since mine came with the tow package and has the transmission cooler I still find the transmission temp can creep up over 225 going up hills. Not sure what size trailer you are looking at but a external trans cooler plus a good equalizer tow package are a must.
  4. Aug 10, 2020 at 3:45 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Somewhere around 4500 should be considered max. And closer to 3500 is a good idea. It's not pulling the weight that is that is the issue. It is the weight a trailer puts on the suspension. Most of these trucks are rated at 6500 lbs, but that assumes a skinny driver with no passengers or cargo in the truck.
    Most Tacoma's have around 1200 lbs payload, but it varies. A 4500 lb trailer will put half of your usable payload on the hitch leaving only about 600 lbs for the driver, passengers and cargo in the truck. And 600 lbs doesn't go far. My Honda Fit has 850 lbs payload. With a 4500 lb trailer behind my Tacoma I can carry 250 lbs more inside the Honda than I can my truck.
    If you want to bring firewood, a generator, or anything else in the truck then you need to be looking at around 3000 lbs.
  5. Aug 10, 2020 at 4:45 PM
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    Agreed, the extra items need to go in the trailer so only 10% is taken away from your payload. No saying to put your family in the trailer while towing LOL!
