Weight and MPG effects of Trail Armor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eagle, Oct 31, 2013.
  1. Oct 31, 2013 at 12:32 PM
    Eagle
    Eagle [OP] Active Member
    What's the total added weight for trail armor, say a tubed front and rear bumper with tubed sliders and new skid plates for an 04 DC TRD taco?
    From what I can find online, it looks like around 240-320 lbs depending on options and such. What kind of effect has it had on your mileage?
  2. Oct 31, 2013 at 12:36 PM
    Large
    Large Red
    Front bumpers vary, as do rear bumpers. It's not so much as the weight of the front bumper though, it's the aerodynamics of it that would affect the MPG more than the weight. Obviously weight has an affect on MPG but to what extent - I don't know.
  3. Oct 31, 2013 at 12:37 PM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    Yeah I'd say closer to 320 lbs if not a little bit more.
  4. Oct 31, 2013 at 12:39 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I was getting 18 - 19 avg on my second gen with lift and tire. Now I get 17-18 with a plate bumper and steel skid.
  5. Oct 31, 2013 at 1:40 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Lift height is going to kill MPG more than weight, to a point. On my old '04, I went from consistent 19-20 to 17 with a 2" lift and an A.R.E. shell, to 16 with a FROR on the rear, ARB+M8000 up front and a hi-lift and tools in the back.
    However, the hurt on the wallet partly depends also on driving style and driving type. On the freeway it's not bad. In the city I would drop down as low as 15.
  6. Oct 31, 2013 at 1:44 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, the weight won't do much. I know I have a 2nd Gen but I added a shell, plywood platform and keep tools in the bed that, together, weigh about as much as you're looking to add with armor. I'm still pushing 20 MPG's because of the improved aerodynamics I have with the shell.
    Tires also play a large roll. Taller, wider and more aggressive tires with a higher load range will kill your mileage.
  7. Oct 31, 2013 at 4:34 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    I've got a 2004 Xtra cab, SR5, 4x4, V6, TRD.
    The factory skids (IFS, transfer case) weigh around 20 lbs total. The Bud Built Skids weigh around 120 lbs.
    The factory front bumper (and cross members) weigh around 25 lbs. The Elite plate bumper (without light hoop and guards) weighs around 110 lbs.
    The factory rear bumper and brackets weigh around 30 lbs. The factory receiver weighs around 50 lbs. The Elite plate bumper w/ built in receiver weighs 95 lbs.
    I don't know how much sliders weigh; I haven't made it over to Fastenal to pick them up yet. :) I hope that helps.
  8. Oct 31, 2013 at 4:35 PM
    wrat
    Wyoming
    Oh, and I haven't seen my gas mileage drop any. I know I'm pushing more weight around, so that only means that it is probably only very slight. Plus most of my driving is under 40 MPH.
  9. Oct 31, 2013 at 4:44 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I dropped maybe 1-2 mpg when I added bumpers, sliders, and skids. It's more noticeable in city driving than highway.
  10. Oct 31, 2013 at 4:52 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    True dat covering the bed makes a difference
  11. Oct 31, 2013 at 6:12 PM
    TBeers
    TBeers Well-Known Member
    Montana
    Tacoma DLX 3.4 4x4
    I added just a plate bumper (90 lbs) up front and a tube bumper in the rear (~60 lbs) with no lift and all terrains and got the same. Plate bumper is really aerodynamic…. I get the same MPG (~20.5). Just about to throw on some mud terrains, I'll give you an update.
  12. Oct 31, 2013 at 6:43 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Go with skinny tires. you will save money at the pump every time you fill up (compared to same tires in wider tread) and will perform as well or better than every one else on the trail except in flotation situations. (you just won't look as cool around town)
  13. Oct 31, 2013 at 7:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Im sorry..but can i just say..why are the majority of the first post 2nd gens..
    No offense guys..but..not your style of truck..and while i know some have owned both and thats cool. A lot haven't..im sorry but seeing all the 2nd gen guys lately trying to help 1st gen guys has just been pissing me off lately. Usually causes more harm then good..
    okay...end rant..
    onto the question of the thread.
    Armor all depends on how much you get. You can easily end up with over 400lbs of it if you go that far.
    Weight does make a big difference on the truck, especially with larger tires.
    That said, light armoring probably won't affect it much. When i had just a bumper and sliders..was no differnent. Be like haveing a passenger and a pack maybe.
    Add in more and more armor though..and i can tell you the biggest area it affects is braking. I would almost trade up rims at this point to do the tundra brake swap personally.
    The biggest factor to mpgs and power though are tires. hands down. But that can be fixed with regearing the diffs. Regearing also make the drive train handle weight much better. And despite running at higher rpms on the hwy usually increases mpgs. Why? because the LOAD on the motor is DECREASED with gears. rpms have little to do with it and really. few hundred higher not gonna kill you.
    all in all. A bumper and sliders not gonna effect it much..but if you get the big mod bug and get F/R bumpers, sliders, full skids and bigger tires and such. Regearing will be a must. I can't wait to re gear personally..it is expensive though. But at that point..you won't care haha
  14. Oct 31, 2013 at 8:27 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    If you are that worried about mpgs, get a cheap beater car or ride a motorcycle.
    My mpg went down to 20-22 with tires , lift and some sliders. I have a 4 cylinder taco.
  15. Nov 1, 2013 at 6:55 AM
    TBeers
    Montana
    Tacoma DLX 3.4 4x4
    I tried to find some 33" 9.5 15's (I still think they look badass) but ended up stumbling across trxus Mud Terrians in 31 10.5 15 for $200 with a lot of tread. I run those for the winter and see how they do MPG and wear -wise. They are most definitely taller than a BFG in 31. OP I would just do front and rear bumpers on your truck if you don't rock crawl that much, good MPG and enough protection. But take what I say with a grain of salt, I love new dents.
  16. Nov 1, 2013 at 7:03 AM
    Pugga
    Massachusetts
    Wow, you're really going to get pissed because a 2nd Gen guy gave advice to a 1st Gen guy?? Not for nothing but the advice us stupid 2nd Genners gave was damn near the same response you gave... just sayin :rolleyes:
  17. Nov 1, 2013 at 7:21 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I think rule of thumb is you lose ~10% MPGs for every passenger (~150-200lbs).
  18. Nov 1, 2013 at 7:23 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Not even close. That's 2mpg. I still hit 17 mpg with 750 extra pounds.
  19. Nov 1, 2013 at 1:25 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If you don't want second gen help on first gen trucks gp make your own damn forum! I mean seriously when you add armor to both generations of the Tacoma it decreases mileage.
  20. Nov 1, 2013 at 4:09 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    seems kinda like you picked the wrong thread to bust that out on, seems like both 1st and 2nd gens will be affected by adding weight.
