Weight Distribution Hitch Ground Clearance
Discussion in 'Towing' started by JayAre, Jun 25, 2018.
  1. Jun 25, 2018 at 4:59 PM
    JayAre
    JayAre [OP] Well-Known Member
    OR
    13 TRD Sport DCLB
    I have a 2013 DCLB Sport stock height. I got this Equal-i-zer wdh, but the shank that comes with it seems to stick down pretty far. Looking around it seems they are all this way. I have about 10.5" (unloaded) from the bottom of the shank to the ground. Does this seem like enough clearance? I feel like it will scrape going over steeper parking lot inlets, speed bumps, etc.
  2. Jun 26, 2018 at 1:56 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Haven't had any issues dragging when my hitch is on the truck. Is your truck sagging when you have the trailer attached to it:eek:?
  3. Jun 26, 2018 at 1:59 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    If it's like my hitch you can remove the ball section, flip the hitch and reinstall the ball to give more clearance.
  4. Jun 26, 2018 at 10:39 AM
    JayAre
    OR
    13 TRD Sport DCLB
    It doesn't sag when the trailer is loaded. That measure is unloaded. Would be lower if the truck was loaded up for a week of camping though.
    Won't work that way, my trailer would be angled up at that point.
  5. Jun 30, 2018 at 8:29 PM
    NGeorgiaTacoma
    NGeorgiaTacoma Well-Known Member
    NE Georgia
    2014 Full Access Cab 4-cyl
    That would depend upon where you take your trailer. 10.5 inches sounds like a gracious plenty for going down the interstate, but may not be enough if you're making your own road across some desert landscape.
    Not to be snippy, but it either drags or it doesn't. As they say, "A miss is as good as a mile." Feelings really have no part in this.
  6. Jul 9, 2018 at 1:20 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Did you read the instructions for the WDH? The truck should stay level with and without the trailer. The WDH when set properly should keep the same height (or close to). If it doesn’t I would question if you have it set correctly.
  7. Jul 12, 2018 at 2:08 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yeah, if your trailer is offroadable swap out the WDH for a ball hitch of appropriate height once you leave the interstate behind. WDH's don't function well offroad, going through gullies, washouts. The truck/trailer combo can function fine offroad with a ball hitch, the two units move independently, with a WDH, no.
