Weight distribution hitch
Discussion in 'Towing' started by wendypet, Apr 30, 2021.
  1. Apr 30, 2021 at 10:58 AM
    wendypet
    wendypet [OP] Member
    Wendy
    2008 Tacoma double cab 4wh 6 cyl tow package SR5
    none yet....
    Aloha, so as I await my KZ Escape HatchE17 - the dealer (who has been great) is saying that this model will not allow for a weight distribution hitch???? I was certainly set on having one installed - but this is the first time someone said that a particular model would not support this - anyone run across this towing a travel trailer????
    They are saying they can install a sway back (I think this was a typeo and he meant sway bars?- which will be similar?? I know what sway bars look like - but do those distribute the weight as well?
  2. Apr 30, 2021 at 12:25 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Are you talking truck or trailer? Trucks certainly do. Could be the dealer just doesn’t install them. Check around.
  3. May 2, 2021 at 6:51 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    A couple terminology clarifications needed. Some WDH( weight distribution hitches) have anti-sway capabilities built in, many don’t. There are also anti-sway or sway control devices. They’re very basic, can be bought around $30.
    Yes, many trailer manufacturers caution against WDH on their trailers. My first one, a NuCamp 320 Boondock was one. But a anti-sway device was recommended.
    A great site to learn a lot is ETrailer.com. Check out their vids and tutorials.
  4. Jun 28, 2021 at 8:21 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    I tow an rPod 180 without WDH, no problems. That is with an '18 TRD Off Road. I do have an anti sway bar and 500# Sumo springs though. The rPod 180 weighs about 3,500. Not sure of the exact tongue weight, but I did tow it with a Tundra for a few trips with no sway control and had no issues, so the current sway bar is just a precaution.
  5. Jul 3, 2021 at 12:17 PM
    smurfblue40rick
    smurfblue40rick Member
    Rick
    ‘07 Tacoma / ‘72 Fj40
    We bought a 21ft Bullet Crossfire (by Keystone) right before Christmas last year. The dealer recommended a WDH with sway control (Eaz-Lift R3 ?). They set everything up for us. I wonder if the trailer’s tongue length has anything to do with whether or not a WDH can be installed?
  6. Jul 3, 2021 at 2:55 PM
    AZ Pete
    Arizona
    yes it does, as does the capability of the tow vehicle.
    smurfblue40rick and TnShooter like this.
  7. Jul 27, 2021 at 2:56 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    weight distribution hitches are Not necessary if tongue / hitch weight is correct
    if the tow vehicle & trailer are loaded correctly....................seldom the case !!!!
    as the topic of towing persists
    iv only read 2 posts whereby the OP actually weighed the total rig ready for vacation
    on certified scales there was more there than he knew conversationaly
    Iv only read 2 posts whereby brakes were a primary concern.............
    I see full sized p/u (4 wheelers ) hauling full sized campers 13ft high 40 feet long & wider than the p/u by 30-40%
    best done with a Dually that stiil might be taxed
