Weight fell off driveline?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20somethingwidataco, Dec 13, 2018.
  1. Dec 13, 2018 at 11:45 AM
    Jlarso01
    Jlarso01 Well-Known Member
    Jim
    Clearwater, Florida
    2015 Tacoma double cab 5' bed
    None yet
    Yes, you can just be aware that the drive shaft is not as strong as a non rusted one and it does not spin when you are in 2H.
  2. Dec 13, 2018 at 12:35 PM
    96carboard
    96carboard Well-Known Member
    Eh... last I checked, there's no carrier bearing on the front shaft.
    Unless you mean the front HALF of the BACK shaft....
    Only if it came off the FRONT shaft. On the BACK shaft, it will impact both 2 and 4wd.
    Weld it.
    If its not noticeable, its probably not a *serious* problem. However if its close to the carrier bearing, the rubber dampener there may be sucking up the vibes. Could still be adding stress on bearings/ujoints.
    Also, there's enough rust on that shaft that the balance is suspect anyway.
  3. Dec 13, 2018 at 12:51 PM
    20somethingwidataco
    20somethingwidataco [OP] Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    The weight came off right where whatever shaft I'm trying to say joins the carrier bearing. It goes to the front diff though
  4. Dec 13, 2018 at 2:04 PM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    Clean mating surface real good with 90% alcohol and bond it with 2 parts adhesive. You should be good to go.
  5. Dec 13, 2018 at 6:02 PM
    20somethingwidataco
    Will
    Washington State
    It's weird, put it into 4x4 on the way to work today. 20mph - 55 mph felt great, no vibrations at all. Even while in neutral
  6. Dec 13, 2018 at 6:13 PM
    Markcal
    Markcal Well-Known Member
    Would JB Weld work for this application?
  7. Dec 13, 2018 at 6:24 PM
    Jlarso01
    Jim
    Clearwater, Florida
    None yet
    Does the drive shaft in question drive the front wheels or the rear wheels?
    Yes JB weld would work.
    Alcohol will not remove or neutralize rust, just degrease it, bonding to rust will lead to failure again.
    Sae68 likes this.
  8. Dec 13, 2018 at 6:27 PM
    20somethingwidataco
    Will
    Washington State
    Drives the front wheels.
  9. Dec 13, 2018 at 6:27 PM
    20somethingwidataco
    Will
    Washington State
    Again it's not really rust as its mud and other crap I haven't cleaned. Probably looks just fine if I pressure washed it
  10. Dec 13, 2018 at 6:28 PM
    Jlarso01
    Jim
    Clearwater, Florida
    None yet
    Still recommend my original post.
  11. Dec 13, 2018 at 6:31 PM
    Jlarso01
    Jim
    Clearwater, Florida
    None yet
    At the minimum it needs to be wire brushed or wire wheeled to clean flaky rust then degreased before attempting to bond weight back on. Pressure washing may remove the loose rust and a good start to the clean up process.
  12. Dec 13, 2018 at 6:45 PM
    20somethingwidataco
    Will
    Washington State
    Ya I'll have to do that. It was relatively clean underneath but a good wash would help.
  13. Dec 13, 2018 at 11:08 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Mine is a 2011 with 210k miles. Absolutely zero rust on the frame, drive shaft and rear axle. I don't get it, by chance do you know what plant yours was manufactured in? Mine was Texas
    :eek:
    Even grandpa's 1998 GMC Sierra isn't rusted..
    :anonymous:
    I seriously didn't know that rusted frames/vehicles were even still a problem until I got on Tacoma world. This has been crazy for me haha
    Also, if you're going to remove the driveshaft to do any work on it, it may be a good time to replace your spiders if you haven't done so in long time of of they need it. Two birds with one stone!
  14. Dec 14, 2018 at 4:27 AM
    96carboard
    Like I said, there's NO CARRIER BEARING on the FRONT SHAFT (the one that goes to the front differential). There's just a shaft with 2 u-joints on it.
