Weight for Cooper Maxx and STs?
Discussion in 'Wheels & Tires' started by stump jumper, Aug 14, 2015.
  1. Aug 14, 2015 at 10:59 AM
    stump jumper
    stump jumper [OP] Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Tire rack does not list them and the Cooper website does not have weight. I emailed Cooper because I am looking at the 265/75/16 in load range E because that is all they have. My current tires weigh in at 49 lbs so I can handle the 51 that a lot of the AT and MTs in this size weigh. Does anyone know the weight for these?
  2. Aug 14, 2015 at 12:59 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    I have been looking into these and this very topic lately. And specifically on 265/75/16 St Maxx. There is no definite answer out there.
    I also did some research of this the myth of tire weights and fuel economy. On several engineering forums, many professional engineers concurred that just a few pounds of additional tire/wheel weight would NOT impact "Rolling Resistance" (the engineering term). Other factors such as aerodynamics of the sidewall, the tread lugs, tire pressure, rigidity, and how much the tire extents past the wheel well have the biggest impacts on Rolling Resistance & fuel economy. Obviously if they were 20lbs more each, they may be an impact, but not a 10% increase in weight.
    I am not thrilled about going from my C load range Duratracs, to load range E. But The noise is getting out of hand. and the new BFG KO2 only come in load range E too.
    49lbs
    http://www.treaddepot.com/tire/90000003094.html
    54lbs according to this guy referencing Discount Tire Now. But if you continue reading, a poster says his 285 weighed 7lbs more than what was reported.
    http://www.jeepforum.com/forum/f15/cooper-discoverer-st-maxx-jeep-lj-rubicon-1364065/#post13513103
    54lbs
    http://www.amazon.com/Cooper-Discov...1876&sr=8-1&keywords=cooper+st+maxx+265+75+16
  3. Aug 14, 2015 at 3:36 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Ok so I got some weights of different tires, no ST Maxx though, we don't make those at our plant... But this will give an idea of some tire weights all tires are load range E
    Cooper ST 265/75/16- 48lbs,
    Mastercraft courser MXT 295/70/17- 58lbs,
    MXT 305/65/17-59lbs
    Cooper AT/3- 265/70/17- 50lbs
  4. Aug 14, 2015 at 3:39 PM
    tommyhd03
    tommyhd03 Well-Known Member
    tommy
    spartanburg
    Sport Tacoma double cab long bed
    885 coils, blistein 5100 front and rear, 1 1/2 AAL. SCSI sr8 wheels, 285/70/17 cooper discover at3 tires.
    I just recently got cooper discover at3 in a 6 ply 285/70/17 and they weigh 45lbs a piece. That sealed the deal for me!
  5. Aug 14, 2015 at 7:21 PM
    stump jumper
    Bill
    Texas
    I noticed that most Es are around 51 but some of the Cepeks are listed at 57. I think width, rolling resistance, compound and tread design will impact MPGs more than weight. That said I think the Coopers will be comparable to the Duratracs and the D load BFGs I have now. I ran some MTRs once in Es and MPGs were same as Duratracs replaced with.
  6. Aug 15, 2015 at 6:07 AM
    tommyhd03
    tommy
    spartanburg
    With the cooper 285s
    Adams22 likes this.
  7. Aug 16, 2015 at 1:20 AM
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    ...just mounted cooper ST 255/85/16 load range D, not thinking about the weight.IMG_2585.jpg
  8. Aug 25, 2015 at 10:44 AM
    stump jumper
    Bill
    Texas
    I found a website that had weights for the Coopers. ST in 265/75/16 load range E is 49 lbs. The STTs are much heavier at 55.
  9. Aug 25, 2015 at 10:56 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Not that it matter but if anyone is curious the heavier STT Maxx is heavier because it's a commercial grade tire. The tire is overbuilt rather than just good enough for it's weight rating which results in a longer lasting tire that's also more puncture resistant. That's why the STT Maxx is becoming more and more popular. I'd stick it right up there with the Wrangler MTR for puncture and tear resistance but it's much more mild mannered for a weekend warrior than that mud tire. We had terrible luck with Cooper before the STT Maxx came out. Now I question using anything else for commercial duty and even on my light duty Tacoma.
    Your PSI, tire size, and lift will effect your mpg more than the weight.
    trailbound likes this.
