Weight in Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stbear, Jan 16, 2017.
  1. Jan 16, 2017 at 1:04 PM
    stbear
    stbear [OP] Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Will I have any problems with a 600 lb load in the bed. DCSB stock with shell and probably 700 lbs in the passenger compartment? Going about 25 miles on highway. Can make 2 trips if necessary to avoid damage to truck. Thanks.
  2. Jan 16, 2017 at 1:07 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    You'll be fine. On my last move I had an 1100 pound difference between empty and loaded. I recommend securing and centering the load as much as possible and maybe just a bit forward of the rear axle.
    NAAC3TACO and stbear[OP] like this.
  3. Jan 16, 2017 at 1:15 PM
    JcDillon
    JcDillon Well-Known Member
    Somerville, Tn
    2012 access cab taco
    Bed Lights, Camper Shell w/ led light strip, HUWMS, K&n 63 series CAI, mbrp s5326al exhaust, ride rite dual control airbags.
    Why not get a trailer and tow all the weight?
    stbear[OP] likes this.
  4. Jan 16, 2017 at 1:21 PM
    stbear
    SE PA
    Thanks. Load will fit between the wheel wells and fill the bed.
    Cheaper to make two trips than rent or buy a trailer. Thanks
  5. Jan 16, 2017 at 1:29 PM
    ABNFDC
    Granite State
    What is in the passenger compartment. I'm operating under the assumption that it is just people. If not, what would it be?
    You're still good with that weight, but if you ever do have to move something larger, Uhaul actually has surprisingly low rates for trailers. 1 day with a 6x12 was $30 last year. A lot cheaper for their smaller trailers. Note that you would need an adapter for uhaul's trailer light connector-they use a 4 pin plug.
  6. Jan 16, 2017 at 2:58 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Suggest airing up your tires to sidewall max.
  7. Jan 16, 2017 at 5:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Payload on my truck is 1200 lbs. You'll technically be overloaded assuming yours is the same as mine, but for an occasional short trip I'd probably do it. Not something I'd do on a regular basis or on a long trip.
  8. Jan 16, 2017 at 5:46 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I hauled about 1200 lbs of rock in the back of a 1995 Nissan Hardbody 4 cyl for about 10 miles. No issues, but I drove slow.
  9. Jan 16, 2017 at 6:35 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I've had mine overloaded a few times. When the sweetie wants landscaping rocks, you get them for her. She don't care what the truck thinks! My truck hated it, by the way. ;)
  10. Jan 16, 2017 at 8:02 PM
    Jalockett
    Jalockett Well-Known Member
    Joshua
    Houston, TX
    '11 Prerunner V6 Sport
    Fire Department based modifications
    I had a 1100lb quad in the bed of my truck, while pulling a 4500 pound trailer (after load) for the fire department... Needless to say I was quite happy when the recall letter for my Springs showed up a day later.
    Edit: I only went about 2 miles and I didn't hit above 15 mph before I unloaded the trailer at the fire house.
  11. Jan 16, 2017 at 9:14 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    Yeah I had a bed full of firewood (read: overloaded) pre- leaf spring recall that made for an interesting ride. Especially around turns. Made it just fine though. too bad the new recall leaves are only marginally better.
  12. Jan 16, 2017 at 9:59 PM
    Jalockett
    Joshua
    Houston, TX
    True, but at least my shackle isn't busted open anymore. Though I am surprised that the dealership didn't question it.
  13. Jan 16, 2017 at 11:42 PM
    stbear
    SE PA
    My load and unload crew was in the passenger compartment.
  14. Jan 16, 2017 at 11:45 PM
    stbear
    SE PA
    Thanks everyone. Everything went smooth and no broken parts, people, cargo or truck.
  15. Jan 17, 2017 at 3:36 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Nissan not a Tacoma. My 2004 Sportrac handled heavy loads much better than Tacoma. Ex filled the bed with rock once and it barely squatted.
  16. Jan 17, 2017 at 6:40 PM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I'm not brand loyal, bro. My point is, if a 4 banger 95 nissan can haul 1200 lbs his V6 will be fine.
  17. Jan 17, 2017 at 11:56 PM
    stbear
    SE PA
    I was more concerned about the suspension rather than the engine being capable.
  18. Jan 18, 2017 at 3:29 AM
    stump jumper
    Bill
    Texas
    Exactly
    stbear[QUOTED][OP] likes this.
  19. Jan 18, 2017 at 7:54 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    700 lbs in the bed (cab empty) of my 11 TRD OR with the pre-TSB 3 leaf springs set me down right on the bump stops. The 4 leaf TSB springs handle 500 lbs in the bed and I'm sure it will take more but I haven't pushed it. But 1,300 lbs total between the cab and bed? I don't know about that. The 2011 OR model was only half ton truck in the advertisements. Hopefully the 15 is better.
    Edit - Just read post #14. Glad it worked.
