Weight in truck bed during the winter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacome4life, Sep 8, 2015.
  1. Sep 8, 2015 at 7:48 AM
    Tacome4life
    Tacome4life [OP] Member
    How much weight should I put in my truck during the winter months? (01 Tacoma) I usually do 120 pounds per back tire. Too much ? Or should I add more ? Just curious what other people do with their tacomas.
  2. Sep 8, 2015 at 7:50 AM
    Madjik_Man
    Colorado Front Range
    Do you have a topper?
    With a topper I don't add anything. If I am heading up to the mountains in a wintry mess, then I'll throw a 50 lbs bag of cat litter over the rear axle in between the wheel wells.
  3. Sep 8, 2015 at 7:59 AM
    Tacome4life
    I have a tonneau cover. No topper
  4. Sep 8, 2015 at 10:51 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    2wd or 4wd?
  5. Sep 8, 2015 at 12:39 PM
    Tacome4life
  6. Sep 8, 2015 at 12:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    You don't tell us where you live
    If you have a lot of snow/sleet, proper winter tires on some OE rims will get you all your 4WD can handle. Don't forget, stopping is important too. And weight in the rear isn't gonna do a thing for that, but winter tires will.
  7. Sep 8, 2015 at 2:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Where you live has quite a bit to say.
    Then just where your trying to go
    I have anything between 800 to 1200 pounds or nothing at all with good Snow tires .
    With the weight very seldom do I need to shift into 4 High
    Then temperature plays a big roll Water makes things slippery
  8. Sep 8, 2015 at 2:55 PM
    Tacome4life
    I live in New England
  9. Sep 8, 2015 at 4:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    New England is a small area, but varies greatly in road conditions and winter conditions.
    So far, post #6 still seems reasonable.
  10. Sep 9, 2015 at 7:19 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    As stated, tires are going to be better than weight. you got 4wd to get out of slippy situations. get some studded tires, you can run them from Nov to April (at least in PA).
    I use to put in a 150lb elevator weight and two 70lb sand bags under a cap ~150lbs. Then realized I was never really needing it for the few off-chances snow would lay and killed my mpg worse (16 down to 11).
