Weight Limit for Tailgate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeepThunder, Feb 25, 2020.
  1. Feb 25, 2020 at 5:41 PM
    JeepThunder
    JeepThunder [OP] Member
    Brian
    2005 Toyota Tacoma Regular Cab
    Hey,
    I want to haul my 700lb motorcycle in the bed. But I am concerned about how much weight the tailgate will hold. The last thing I want is to ride up the ramp to have the gate bend or fall off. So am I safe or do I have to reinforce the gate and/or gate cable?
    I have a 2005 Taco
  2. Feb 25, 2020 at 5:48 PM
    jungleman
    jungleman There can be only one
    North California
    2005 Access Cab Indigo Blue
    Pine needle or leaf
    But not both at the same time.
    But seriously I loaded and unloaded my quad thousands of times without dropping the cables and it is slightly bent in the middle.
    I trailer my quad most of the time now.
    Tons of reinforcement mod pics and threads, check out the "what have you done today" top sticky.
  3. Feb 25, 2020 at 5:50 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
  4. Feb 25, 2020 at 5:59 PM
    HighCountryTacoma
    Colorado
  5. Feb 25, 2020 at 6:00 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Hit the ramp faster and you won’t even touch your tailgate. Works better in a long bed though.
    j4kc87, Jensonbt and jungleman like this.
  6. Feb 25, 2020 at 6:01 PM
    JeepThunder
    Brian
  7. Feb 25, 2020 at 6:57 PM
    JeepThunder
    Brian
  8. Feb 25, 2020 at 7:09 PM
    HighCountryTacoma
    Colorado
    I wouldn't be too concerned as most of the weight of the bike is towards the front not the rear wheel. Plus I haven't read anybody whining about the "shitty stock cables!" on here or complaining about them so my guess is there fine but if you're concerned about it, I'd probably reinforce or replace them.
    EatSleepTacos likes this.
  9. Feb 25, 2020 at 7:12 PM
    JeepThunder
    Brian
    That is fine once the bike is loaded. How about AS THE BIKE is loaded. The weight is on the tailgate, at least a good portion.
  10. Feb 25, 2020 at 7:17 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    And now you’ve made me hungry, damn you !!! Gonna look for a snack.
    whatstcp[QUOTED] likes this.
  11. Feb 25, 2020 at 7:24 PM
    HighCountryTacoma
    Colorado
  12. Feb 26, 2020 at 2:02 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Cut, fit a slab of 3/4" plywood to distribute weight. Mine is 54 1/2" X 22" with an edge overhang of 2 1/4", so I can clamp something I'm working on. Cut it flush (54 1/2" X 19 3/4") to use with ramps. It won't move, fits against bedposts and between tailgate support cables. Store it under the bed mat.
    Whatever you do, keep loading weight away from the center of the tailgate, the most vulnerable spot, plus the latch hole in the sheet metal is right there, and close to the edge. Worst possible place.
    Or just lift the tailgate off and load directly into the bed.
  13. Feb 26, 2020 at 2:51 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I put my 700lb motorcycle in the back of my Tacoma with no issues.
    1984 Goldwing, standard no jammers.
    DG92071 likes this.
  14. Feb 26, 2020 at 7:09 AM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    Not completely true. Please don't spread false information without doing some proper research. A green leaf is much denser and carries more weight than a properly dried and seasoned leaf. There's almost a 20% difference in weight when green. The tailgate cannot handle that extra 20%. And you also need to be more specific when you say "leaf". Nothing larger than a clover leaf would be safe. The amount of false information on this site is astounding. Hope that clears things up a bit.
  15. Feb 26, 2020 at 5:35 PM
    LJJB
    LJJB Member
    2012 DCSB
    Mine is bent from loading my bikes about once a month, <300lbs and only 1 at a time. You can see light through the bottom when closed
  16. Feb 28, 2020 at 10:33 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Mine is slightly tweaked from sitting on it; I haven't hauled anything heavy that has touched the gate. I weigh 160 lb and the ex GF ~110 lb. So it doesn't take much.
  17. Feb 28, 2020 at 11:33 AM
    Tah-koh-mah
    So you and your ex GF were just sitting on it. Right. Sure. Ok. :thumbsup:
    Muddinfun likes this.
  18. Feb 28, 2020 at 1:05 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I replaced mine last fall because you just never know.
    They might be rusted inside the coating and you would never see it until it breaks.
    I went with OEM but there are cheaper options out there if you feel lucky.
    There's also the option of removing the tailgate for loading.
  19. Feb 28, 2020 at 3:40 PM
    Michaelm466
    Michaelm466 Active Member
    Michael
    Mesa, AZ
    2010 Tacoma TRD Sport
    I just pick up my quad/riding lawn mower/harley and lift it over the side, keep the tail gate up and you don't have to worry about bending it, better eat your wheaties though:curls::benchpress:
    Jensonbt likes this.
  20. Feb 28, 2020 at 3:45 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    I had my tailgate down today and stepped on there before I jumped off. I heard some crackling and popping. It sounded like it was mostly the plastic, but still.
