Weight Limit on Topper????
Discussion in 'Tonneau Covers, Caps and Shells' started by shaunemoore, Feb 13, 2017.
  1. Feb 13, 2017 at 10:05 PM
    shaunemoore
    shaunemoore [OP] Active Member
    Shaune
    2017 Toyota Tacoma TRD Off-Road
    I have a ARE fiberglass topper that has the ORE option (Factory Line X coating). I have the reinforced fiberglass roof with the Yakima tracks and rails. I found a great deal on a AutoHome hard shell roof top tent and i'd like to buy it and mount it on top of my topper. RTT weighs about a 100, I weigh about 180, and the only person I would share it with doesn't weigh anymore than 100 pounds. So in total, at most I would need the topper to support is about 400 pounds while parked and sitting completely still. Can anyone tell me if this is safe to do and whether the topper can support this type of weight? First hand knowledge would be great. Thanks.
    dziner and ready6delta like this.
  2. Feb 13, 2017 at 10:06 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'd ask ARE.
    Sounds perfectly fine from your description, but nobody else knows for sure except the manufacturer. Everyone else is just opinion.
    yonah and cosmicfires like this.
  3. Feb 13, 2017 at 10:10 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Most of the general retail ones do not have the highest load ratings from what I recall. I have a Leer and I recall that I was told if if I wanted more weight I should have picked up the commercial version, they added some support to the topper. Curious on this as well. I need to look up the ratings on my shell.
  4. Feb 13, 2017 at 10:17 PM
    nudavinci64
    Robert
    Found this from Leer's site. I would expect it is similar for ARE. Unless you have a commercial one your prob in the same boat as me.
    When factory-installed on a LEER Model 100XQ, 100XL, 100XR, 100R, 180, or 122, the Thule Aero Bar and Tracker II Roof Rack systems have a maximum load capacity of 150 lbs. When factory-installed on a LEER Model 100RCC or 180CC, the Thule Professional Roof Rack system has a maximum load capacity of 400 lbs. There are other critical factors in safely carrying and securing loads to your roof rack – these factors are explained in the instructions provided by Thule with the roof rack.
  5. Feb 13, 2017 at 10:19 PM
    Taco de Carnista
    Taco de Carnista Well-Known Member
    michigan
    2005 TRD OFF ROAD
    i got a ARE cap with track I mount my JB tent on top with 2 set of thule square bar no problem no sag, the store said that the ARE is good for 450 dynamic load, static is more highesDSC_2363 2.jpg
  6. Feb 13, 2017 at 10:23 PM
    nudavinci64
    Robert
    Is that the commercial topper? Generally the commercial ones are good for 4-500 give or take. Regular ones not so much. didn't think of it myself at the time for a tent.
    shaunemoore[OP] likes this.
  7. Feb 13, 2017 at 10:25 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Did you try googling it OP?
    nudavinci64 likes this.
  8. Feb 13, 2017 at 10:29 PM
    shaunemoore
    Shaune
    I have. Have not found anything concrete. More than anything else I've seen people speaking from their personal experiences that while parked, they've had no issues with the same type of setup as what I'm considering. The toppers max weight limits the companies put out are for dynamic weight loads and do not so much reflect accurate numbers for weight limits that are evenly distributed while parked. So because they only give a dynamic max weight rating, its hard to know for sure one way or another what its actual capabilities are.
  9. Feb 13, 2017 at 10:30 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Bobs your uncle then.
  10. Feb 13, 2017 at 10:32 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Wait...wait you forgot about wind!
  11. Feb 13, 2017 at 10:33 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Then there is snow load!
    PROseur likes this.
  12. Feb 13, 2017 at 10:33 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Zombies...can't forget zombie load.
    TheHippyChick likes this.
  13. Feb 13, 2017 at 10:37 PM
    shaunemoore
    Shaune
    Nice setup, beautiful truck :)
  14. Feb 13, 2017 at 10:38 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Just trying to make this sound as ridiculous as it is.... look at what oz puts on his topper for work and you will understand. Just being playful.
    synaps3 and PROseur like this.
  15. Feb 13, 2017 at 10:39 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    I had a Leer 100xq with a prinsu rack, once carried 8 3/4" plywood on top with no visual problems.
    N64_Wallmaster likes this.
  16. Feb 13, 2017 at 10:42 PM
    shaunemoore
    Shaune
    Im not sure whats ridiculous about it? Seems like a perfectly sensible question and subject to me?
    Logan.spencer likes this.
  17. Feb 13, 2017 at 10:53 PM
    Frkypunk
    Timmy
    Woods of P.A.
    There is a rate loading imprinted on most.
  18. Feb 13, 2017 at 11:04 PM
    shaunemoore
    Shaune
    And? As I've already said, I'm looking for other peoples first hand knowledge on the subject as the load rating you brought up is a dynamic rating. Meaning weighed down and the load is under high stress. The manufacture rating doesn't cover what it can realistically support under the least stressful conditions.
  19. Feb 13, 2017 at 11:06 PM
    shaunemoore
    Shaune
    If its ridiculous as you say, you certainly don't need to waste your time on it. Just keep on scrolling.
    BThorson and fence666 like this.
  20. Feb 13, 2017 at 11:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have a commercial cap
    Hobbs and nudavinci64 like this.
